welding steel furniture???
发表于 2021-8-31 23:29:34 | 显示全部楼层 |阅读模式
Hi everyone, I am new to this forum and did some research but could not find a concrete info about welding steel furniture. My question is what types of welding methods ( such as MIG, submerged etc.) we can use welding steel furniture. Your answers will be very important for me. I hope you will share something. Best wishes
Reply:It's steel - I'm guessing mild steel?You can use oxy-acetylene brazing, oxy acetylene fusion welding, you can use stick, you can use mig, you can use flux core, you can use tig, hell you can probably use a resistance welderTry searching on google...
Reply:Thank you for your answerI am already searching for google but can not find something like why we use those welding types, I mean what are their advantages when they are used for steel furniture Thanks againLast edited by kaytug; 12-25-2011 at 12:20 PM.
Reply:Hey kaytug,You come to the forum & expect an answer to your query & somehow expect useful information leaving us in the vacuum of the Twilight Zone.Provide info. to us in this context:1)  What type of material....CR, HR, Alum., SS, Cast???????????2)  What size furniture do you want to weld & thicknesses of material ??????????3)  Is your query for multiple(more than 1) pieces ??????????4)  Are the pieces each a different physical dimension ?????????5)  Are you going to produce a quantity so we can understand if this is going to be a production run ?????????6)  Are you familiar with production techniques such as jigging/fixturing ????????????7)  Are you looking for the fastest or the most aesthetically important process ?????????8)  Is your query just for repair work ???????????Your indication that you could not find "concrete" data regarding welding steel furniture leads me to believe you are simply attempting to have someone do your "homework"........Sound accurate?????????DennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:Originally Posted by yorkiepapHey kaytug,You come to the forum & expect an answer to your query & somehow expect useful information leaving us in the vacuum of the Twilight Zone.Provide info. to us in this context:1)  What type of material....CR, HR, Alum., SS, Cast???????????2)  What size furniture do you want to weld & thicknesses of material ??????????3)  Is your query for multiple(more than 1) pieces ??????????4)  Are the pieces each a different physical dimension ?????????5)  Are you going to produce a quantity so we can understand if this is going to be a production run ?????????6)  Are you familiar with production techniques such as jigging/fixturing ????????????7)  Are you looking for the fastest or the most aesthetically important process ?????????8)  Is your query just for repair work ???????????Your indication that you could not find "concrete" data regarding welding steel furniture leads me to believe you are simply attempting to have someone do your "homework"........Sound accurate?????????Denny
Reply:Originally Posted by kaytugThank you for your answerI am already searching for google but can not find something like why we use those welding types, I mean what are their advantages when they are used for steel furniture Thanks again
Reply:kaytug don't be discouraged... questions are posted and like a group of BlueGills  fellas respond, chew it up, spit it out  etc.  Being very specific is a good way to go here.  Pictures of examples are good too.  You will find many fellas here who have worked professionally in most fabrication processes. So,  they see 100 answers for your ? MIG with gas for thinner  mild steel might be a general answer for a very general question.This is a Discada for cooking and the 3 legged stool underneath which holds the charcoal.  It is a rough example of cowboy cooking made with numerous tools including a MIG welder with gas.  There are fellas who have made some very fine very smooth work also,Try again, zactlee what is it you would like to make? Attached ImagesLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Originally Posted by PapaLionkaytug don't be discouraged... questions are posted and like a group of BlueGills  fellas respond, chew it up, spit it out  etc.  Being very specific is a good way to go here.  Pictures of examples are good too.  You will find many fellas here who have worked professionally in most fabrication processes. So,  they see 100 answers for your ? MIG with gas for thinner  mild steel might be a general answer for a very general question.This is a Discada for cooking and the 3 legged stool underneath which holds the charcoal.  It is a rough example of cowboy cooking made with numerous tools including a MIG welder with gas.  There are fellas who have made some very fine very smooth work also,Try again, zactlee what is it you would like to make?
Reply:Look into MIG. Very easy to learn. Lower equipment and lower consumable cost. Versatile.
Reply:You still there Kaytug?Contrary to popular opinion, I do NOT have a pet turkey that craps molten steel.  It's a goose.
Reply:Pretty sure that's a spammerMiller: 200dx, Bobcat 225, Passport, Powermax 45, Milwaukee: Dry Saw, MagDrill, grinders
Reply:I like to submerge arc weld my patio furniture. It's easy to do and by far the cheapest method. All you really need is a machine that will run at about 1000 amps and a 55 gallon drum of flux. Then set up the track for the wire feeder and load on 2 60lb spools of 3/32" wire and off you go. CERTIFICATIONS:7018M- H.V.O10718M- H.V.O11018M- H.V.O9N10- H.V.O71T-1-HYM- H.O.V100S1 PULSE ARC 0,035- H.O.V100S1 PULSE ARC 0.045- H.O.VER70S-3 PULSE ARC 0.035 H.O.VER70S-3 PULSE ARC 0.045 H.O.VER5554- H.O.V
Reply:kaytug - I recommend you friction stir weld your patio furniture. I've seen a reduction on the cost per unit by welding that way. Plus you don't need any filler metal.best wishes..."The trouble with quotes on the Internet is that you can never know if they are genuine." - Abraham Lincoln
Reply:I'm hoping we get a lot of youngsters from the goats this winter.  I'm due maybe 5-6 for sure... those will be  ready to butcher the following Christmas, about a year from now... so s BBQ/smoked Cabrito would be a possible.  We've talked about this before, I like the idea if my health holds at all it might just happen  late 2012.I think we scared off the young fella... got any pics of those patio furniture methods? Never heard of that might be real kool to see.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Well I can see that this thread was no help to anyone.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Hey guys,Well, since this thread is at its conclusion & the spammers want to invade......bye...bye.DennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
GMT+8, 2025-12-26 17:52 , Processed in 0.073079 second(s), 18 queries .
