Welder's cart idea's
发表于 2021-8-31 23:29:31 | 显示全部楼层 |阅读模式
I've seen a bunch of welding machine carts on here, but I'm wanting ideas on a cart for holding all of your fabrication tools. Grinders, safety items, abrasives, layout tools, clamps, etc. Something you can move around the shop. We end up working on large projects and I hate running around getting tools, so much wasted time. I also hate when I'm working on the welding table having to set my hood, mask, etc on a table covered in grit.So I'm wanting ideas on a small efficient cart.Dynamic MetalworksMontrose, CODynMetalworks.com
Reply:::15 of GoogleFu = http://www.garagejournal.com/forum/s...d.php?t=168322.  Define your requirements, then build a rig with this functionality.  GTG.Last edited by ManoKai; 08-08-2013 at 11:14 AM."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:This is one I built.  It is movable, but needs better wheels.  I built it for my welding equipment as I use a different cart for my grinding and cutting items. Attached Images
GMT+8, 2025-12-26 15:46 , Processed in 0.094287 second(s), 18 queries .
