Tried to search couldn't find. Sorry if this might be stupid. I was wondering if you can wire a dinse plug conection on one end and a wall plug for 110 or 220 on the other. I have someone who is wanting to sell me a suitcase feeder welder for cheap. I was looking for a miller passport plus but can't really find them locally or a good deal online. His welder is the miller with the dinse plug connection. Or I was wondering if the plug can be removed and wired like the miller passport plus.Last edited by Stretch561; 08-12-2013 at 07:59 PM.
Reply:No, no and nowww.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:you would need a power source for the suit case feeder IIRC a welding machineMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Not trying to be rude, but there is no way to go from Dinse to a wall plug without an actual welder in between. Attached Images
Reply:Isn't the DINSE plug where the power comes OUT, rather than goes IN, the welder?(I don't think that's reversible, or at least not recommended.)
Reply:Originally Posted by WookieWeldingyou would need a power source for the suit case feeder IIRC a welding machine
Reply:Kelvin the welder is the miller extreme rc. It has a dinse in rear for power source, such as another welder. It has the amp and wire speed control in front. So in question I was curious to if it was possible to bypass dince plunge just like the passport plus. Thanks for the info on this guys. Wasn't to sure about it. It my head it seamed logical but then again as someone once told me, the hell with logic.Drf25 I know e passport and extreme rc are different, but I guess I was questioning how different they really are. Appearenc whys they seem e same just one has a MVP plug I believe, and the other has a dinse. Not to sure about the internal boards. That's the thing that gets me.Last edited by Stretch561; 08-13-2013 at 07:33 AM.
Reply:Stretch, the part you're missing in this picture is that the Passport is a complete, self-contained welding power source and wire feeder all in one.The Extreme RC is NOT a welder as you've stated but rather simply just a remote wire feeder that requires a separate power source as has been pointed out already by others. Again, that Dinse connector is for the welding power source output to the Extreme feeder weld current input. No 115VAC household type plug required nor will be of any use as the feeder drive motor gets its power from the appropriate power source.Bottom line - the Passport and Extreme RC are apples and oranges.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base! |
