What do you use for acetone wipes?
发表于 2021-8-31 23:29:30 | 显示全部楼层 |阅读模式
Wow that title took a bit of thought to avoid all the a$$ puns...Anyhow, hobby welder here, and trying to figure out what to to use when cleaning steel with acetone that won't leave lint of some sort behind.I've tried rags, high end paper towels, my wife's face cleansing pads, and everything I use leaves lint behind.Since this is a hobby, it seems like it could take forever using trial and error to get an answer to what should be a simple question, and I couldn't find any threads where someone else had asked, so...What do you use to wipe your steel with acetone that does NOT leave some sort of lint behind?Thanks,BillLincoln v155-s with Tig Welder Ready Pack K2606-1One father's love of his autistic son www.inmyimage.com
Reply:The bottom inside of my Tshirt, I buy bigger just for that reason. Anyone that disagrees is a bold face liar   TrueI hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:I usually use blue shop towels (strong paper towel). http://www.homedepot.com/p/Scott-55-...3#.UgldLp3D-M8Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:i use Kimwipes kimtech science brand they leave nothing behind made by kimberly-clarkMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Maybe Bounce Dryer Sheets...???
Reply:Originally Posted by ZZWELDMaybe Bounce Dryer Sheets...???
Reply:Mike's probably right about the t-shirts; I'm still learning about welding but this question's kind of up my alley. Lens cloth we use for camera lenses. They're completely non-abrasive character is why we use them but they also leave no foreign particles behind for obvious reasons. Also, there's automotive tack rags. They're used to finish-wipe car finishes prior to color coats because they too leave absolutely no foreign particles.
Reply:just get the towel 'wet' so that it does not become dry and leave fibres. In other words, be generous with the acetone, because it dries into the towel/dissipates really quickly and the towel ends up dried out which leaves fibres. You can also 'pat' down the metal once normal cleaning is done
Reply:Originally Posted by jlamesMike's probably right about the t-shirts; I'm still learning about welding but this question's kind of up my alley. Lens cloth we use for camera lenses. They're completely non-abrasive character is why we use them but they also leave no foreign particles behind for obvious reasons. Also, there's automotive tack rags. They're used to finish-wipe car finishes prior to color coats because they too leave absolutely no foreign particles.
Reply:Stainless brush...CLEAN rags...Air hose with a blow nozzle after for those pesky lint things that don't add up to anything anyway....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Here's a link to the Chem wipeshttp://www.amazon.com/s/?ie=UTF8&key...l_9r3yguytdn_e
Reply:Originally Posted by zapsterStainless brush...CLEAN rags...Air hose with a blow nozzle after for those pesky lint things that don't add up to anything anyway....zap!
Reply:Clean rags.
GMT+8, 2025-12-26 15:45 , Processed in 0.151628 second(s), 18 queries .
