Chemical tungsten sharpening?
发表于 2021-8-31 23:29:26 | 显示全部楼层 |阅读模式
When I got my PT185, the guy gave me this stuff called CHEM SHARP tungsten electrode sharpener, made by Dynaflux, INC.Directions: pointing tungsten using tig torch as heat source. Extend tungsten stick out approximately 1" beyond cup. Short out tungsten against ground clamp work piece until glows cherry red, approximately 3/8" up from tip. Quickly immerse the heated tip approximately 1/4" deep into this product repeatedly until desired point is formed. If desired point is not yet formed, quickly re-immerse tungsten into the product. If reaction does not restart repeat procedure. Anyone know about this stuff or use it? It looks like salt in a glass jar. Needless to say, I am a little hesitant to short out my new welder until the tungsten starts glowing red.
Reply:Doh, what do you mean I should search a little bit!!!!??http://weldingweb.com/vbb/showthread.php...ght=chem+sharp
GMT+8, 2025-12-26 16:08 , Processed in 0.093389 second(s), 18 queries .
