For your Next Shelving Project--A new design!
发表于 2021-8-31 23:29:26 | 显示全部楼层 |阅读模式
Needed a set of shelves to sit onto of a desk that I built and thought what the heck let's go with unique and innovative.  This might provide a few ideas for your next set of supports.  Will probably have this powder coated black to match the desk. Cheers and best wishes for the New Year.
Reply:Nice. I've seen designs like this before. You might want to think about using a dimple die on the holes for future ones. Makes for a bit cleaner look and helps stiffen the metal. Not sure about the corner / ends though. I like the look of the top shelf, but the lower ones look a bit clunky. I might have notched the shelves so you keep that clean look  without having to see the connections, or thought about some sort of redesign. Having the "legs outboard of the shelf might be an option, but I'm not sure if I'd go that route..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Looks cool. That should be plenty strong for a bookcase.I did not see anywhere that you wanted it redesigned as the previous posted thought you did.Miller Diversion 180Lincoln Mig Pak 5000 HDHypertherm 45Uni-Spotter Stud WelderOxy Set-up with Harris TorchMiller 30FX Arc StationMiller Elite - Hockey Canada Helmet
Reply:I like it! I don't think any dimple dies wouldn't fit that (i know mine wouldn't). I like how you made all the pieces the same (shelves and "legs"). You could crank those out fast. Sell them in sets of three.www.performancealuminumfabrication.com
Reply:Thanks gents, here's what it looks like unpainted but set up on the desk. Don't think you could get dimple dies into 1X3 11 gauge rectangular tubing.  These will probably hold the heaviest thing on the planet.....National Geographic Magazines!
Reply:That's nice! Look cool with 1/2 glass shelves too. Me likey!!! Are you going to sleeve the holes with slices of tube? Lotta work but would look sweet.B200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:Bert--tubing would be cool, but I think I'll call it good on these right now, I have about 2 zillion other projects backed up, perhaps when I pull it down to powder coat it.  Thanks!
Reply:Originally Posted by 200mphbusaThanks gents, here's what it looks like unpainted but set up on the desk. Don't think you could get dimple dies into 1X3 11 gauge rectangular tubing.
Reply:How about welding some pieces of tubing through the holes? That would look pretty trick too, I have seen that before.... Nice work manHTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:Nice work.  What do you think the powder coat will cost?Contrary to popular opinion, I do NOT have a pet turkey that craps molten steel.  It's a goose.
Reply:GraniteGuy-Thanks, I take my stuff to a local fellow that I believe is pretty reasonable I am guessing based on other stuff he has done for me that this will be about $65, I'll take it in with a headache rack that I am doing for my truck and have stuff done as a lot.
Reply:Originally Posted by fordmanHow about welding some pieces of tubing through the holes? That would look pretty trick too, I have seen that before.... Nice work man
Reply:Originally Posted by bert the welderDunno why, but that suggestion sounds familiar............
Reply:Originally Posted by 200mphbusaGraniteGuy-Thanks, I take my stuff to a local fellow that I believe is pretty reasonable I am guessing based on other stuff he has done for me that this will be about $65, I'll take it in with a headache rack that I am doing for my truck and have stuff done as a lot.
GMT+8, 2025-12-26 15:56 , Processed in 0.119543 second(s), 18 queries .
