Welding art
发表于 2021-8-31 23:29:22 | 显示全部楼层 |阅读模式
Ran across a art exhibit yesterday and saw a few interesting pieces.Someone burned a lot of ros as filler.Sent from my DROID RAZR using Tapatalk 2 Attached Images
Reply:Those are some interesting pieces, and I'd agree whoever built them used a lot of filler metal.  Can you imagine what we'd have to charge to sit there for two days and fab one of those up?Matthew MortonTexas A&M '06Logsdon Seminary '13"Who Dares Wins""AFTF""WH2PH"SA 200 (Code: 5337)TB 302CP 302 w/22A Wire FeederMillerMatic 200Miller Syncrowave 200MillerMatic 252BurnTables 4x4 CNC MachineHypertherm 65
Reply:Should have been rod no rosSent from my DROID RAZR using Tapatalk 2
Reply:Definitely alot of patience!!! I definitely could not do that!
Reply:I dig it, but I think I would be quite unhappy with the way the inside turned out, as mine would definitely not be that smooth
Reply:Originally Posted by matt1morton  Can you imagine what we'd have to charge to sit there for two days and fab one of those up?
GMT+8, 2025-12-26 17:38 , Processed in 0.152663 second(s), 18 queries .
