Hello,I joined a few days ago and have many questions. But right now the one that I have on my mind is this-Is a Dayton 85 Amp Dual Purpose Wire Feed Welder 6Z935B with a 20% duty cycle a rebranded Century welder?I just got a tank of 75/25 gas for it and am going to put the original regulater (Victor brand )that I got with it on it. Luckily I still had the instruction manual and it states that the regulator is fixed to pass 25#s per hour.Does the Tweko(spelling?) gun have a valve inside of it so the gas flows when I squeeze the trigger? Thee manual does not get into that at all.I have used it with fluxed wire but this will be the first attempt to use gas.Any advice is welcomed.Regards and thanks,FredLast edited by pelallito; 03-06-2011 at 11:52 AM.Reason: Corrected model # can't read own writing:>(
Reply:Originally Posted by pelallitoHello,I joined a few days ago and have many questions. But right now the one that I have on my mind is this-Is a Dayton 85 Amp Dual Purpose Wire Feed Welder 62935B with a 20% duty cycle a rebranded Century welder?I just got a tank of 75/25 gas for it and am going to put the original regulater (Victor brand )that I got with it on it. Luckily I still had the instruction manual and it states that the regulator is fixed to pass 25#s per hour.Does the Tweko(spelling?) gun have a valve inside of it so the gas flows when I squeeze the trigger? Thee manual does not get into that at all.I have used it with fluxed wire but this will be the first attempt to use gas.Any advice is welcomed.Regards and thanks,Fred
Reply:Thanks for the answer jbmprods!I have not finished conecting the gas line to the machine or switching the polarity. Then I will test it.Thanks again,Fred |
