6022
发表于 2021-8-31 23:29:18 | 显示全部楼层 |阅读模式
I saw some 6022 rod the other day and was just curious what it is like.Did search and seems like it is a "decking rod". Flat/horizontal only. Was wondering how it runs...like 6010/11? Any other uses for it?AlA man is judged by what's between his legs...always ride a good horseMiller DialArc HFLincoln Classic 300DThermal Arc 181iPowermax 45Scotchman Ironworker(2) BridgeportsOkomota Surface GrinderAutoCAD 2010
Reply:It is a decking rod. It is used to plug weld decking to structure. Works very well in that app. I have never ever tried it any other way.QamuIs Heg qaq law' lorvIs yInqaq puS
Reply:Its only used for the 5/8" puddle weld for decking.  Won't work on anything else.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:Thanks guys. Just seen some the other day at an auction and got to wondering about it.AlA man is judged by what's between his legs...always ride a good horseMiller DialArc HFLincoln Classic 300DThermal Arc 181iPowermax 45Scotchman Ironworker(2) BridgeportsOkomota Surface GrinderAutoCAD 2010
Reply:Maybe you could chip off the flux and use them for NINJA  spears?[ame]http://www.youtube.com/watch?v=LSJlyZjS6Pk[/ame]  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:[QUOTE=B_C;482705]Maybe you could chip off the flux and use them for NINJA  spears?QUOTE]Who lays awake at night thinking,  "I wonder what I could do with the welding rod that's out in the garage?"And do we any longer wonder why they say there will be a shortage of welders in the future?AlA man is judged by what's between his legs...always ride a good horseMiller DialArc HFLincoln Classic 300DThermal Arc 181iPowermax 45Scotchman Ironworker(2) BridgeportsOkomota Surface GrinderAutoCAD 2010
Reply:Originally Posted by B_CMaybe you could chip off the flux and use them for NINJA  spears?
Reply:Its a puddle spot weld.6022 has been used by many ironworkers to weld bridging into joists. Most engineers are requiring a 70-series rod these days though. Even had some jobs require 70 series rod for the deck welds.
GMT+8, 2025-12-26 19:20 , Processed in 0.151933 second(s), 18 queries .
