FCAW overhead with ceramic tape.
发表于 2021-8-31 23:29:18 | 显示全部楼层 |阅读模式
Im looking to some tips/facts together in regards to taking a FCAW overhead test with ceramic tape. All replies are appreciated!Thxs.
Reply:Getting tips/facts together i meant.
Reply:Go here for info on the process.http://www.safex.in/wbt.htm#ceramicPhoto below of the foil ,high temp tape and ceramic tiles.Last edited by Donald Branscom; 03-08-2011 at 01:02 PM.AWS certified welding inspectorAWS certified welder
Reply:Im familiar with ceramic tape itself.Im just not certain about using it overhead, seems to me the puddle will fall out ounce its generated. Bc unlike running stringers you have to root and fill at the same time. IDK
GMT+8, 2025-12-26 17:28 , Processed in 0.104682 second(s), 18 queries .
