Flange Adapters
发表于 2021-8-31 23:29:17 | 显示全部楼层 |阅读模式
here is some stuff i did today, they are what I call flange adapters.  basicly what happend was customer has a alum watter tanker that had some odd ball size flanges on it and since i dont have a tig rig to put in standard flanges i did this took a 4" sch 80 nipple beveled it cut a flange out of 1/2" plate to match the odd ball one then they can bolt that on the truck screw on a standard flange and attach a valve there will be a gasket between the steel flange and aluminum flange. Attached ImagesLincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
Reply:Looks like it will work to me! Did you weld inside the flange too? Or just relying on penetration from the outer weld? Not saying you should, just asking questions. Be careful running your pipe vise on the threads like that, maybe a better idea would be to screw a coupler on the threads, then clamp on the coupler. Either way, well done.
Reply:Looks Good to me Adam.   Hows the 6G practice going?AEAD 200LE, Lincoln precision tig 185, Millermatic 251, Spectrum 625 extreme, Victor torch , Smithy 1220LTD. and  Do all C-4 band saw ,  Always adding.
Reply:Originally Posted by slow6iLooks like it will work to me! Did you weld inside the flange too? Or just relying on penetration from the outer weld? Not saying you should, just asking questions. Be careful running your pipe vise on the threads like that, maybe a better idea would be to screw a coupler on the threads, then clamp on the coupler. Either way, well done.
Reply:I made one a couple weeks ago, a reducer/flange for a wood stove. Cut the 8'' flange out of 1/2'' plate by hand and used 6'', 1/4'' wall pipe and tig'd it.... easy money.Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:i beveld the nipple which was a 4" nipple the cut my flange with a 4" hole gaped it and ran a root pass  hot pass then my cap on my first one tho i did weld from the inside i messed up  hap poor fit up so theat y i did that but i was more carefull on my fit up for #2 never even thought about using a coupler duh me thank goodness for pipe dope lolhavent had much time to work on my 6G  which is good cause im busy with work but bad cause i need to practice dang it.the pic don't show it to well but i did get pennatration all the way  on my root ill get more pics of my pipe practice up soon as i get a chance to do someLincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
GMT+8, 2025-12-26 17:39 , Processed in 0.108766 second(s), 18 queries .
