Todays Fun, Dump Piston on a Tri Axle
发表于 2021-8-31 23:29:15 | 显示全部楼层 |阅读模式
This was the fun for the day, along with a service on the truck and some patch work on the body.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:ouch !!Multi stage ram i take it ...Over hauling it or replacing itBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Sending it to my hydraulic guy for a re sealing, not bad all the leaking oil made it slide right out.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Nice stuff   I'm too old for that sh*t.    DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:How was the top pin to remove? I found that if the top pin has been greased regularly on a dump then the rest of the truck has been maintained. Kinda like if they will go to the trouble to climb in the bed and grease that zirk they were going to get the easy ones as well."Liberalism is a mental disorder" Dr. Savage
Reply:Hey Tozzi, I see that crane is coming in handy.Is that a three stage cylinder on the tri-axle? I have a four from my Hilbilt Mongoose 22' dump trailer that needs repacking. I think I was quoted $550, how much are they charging you? Mine will be easyto pull, because the front is open. I'll post pics when I do it."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:The top pin slid right out as well as the bottom, I don't know the price I just dropped it off. I will let you knoe the damage when it comes back. This one is a 4 stage ram as well.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:I made a clamp to fit the cylinder barrel that would sit on the forklift forks to make easy in and out of dump trailer cylinders. With the clamp and forklift removal and installation was an easy one man job.
Reply:You get all the fun jobs......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:If I didn't have the crane, I would have dreaded this job. As far as I am concerned the truck has paid for itself.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by Stick-man I think I was quoted $550, how much are they charging you? .
Reply:Well, I can take apicture and TRY to post it, but at my age I am still learning this computer stuff. Less than 3 months expirence with this.
Reply:Originally Posted by TozziWeldingI got it back this morning $878  whatever the customer paid
GMT+8, 2025-12-26 17:39 , Processed in 0.229478 second(s), 18 queries .
