Well...It's NOT A Box...
发表于 2021-8-31 23:29:15 | 显示全部楼层 |阅读模式
It's a frame!!!Whoopie.1.5" aluminum angle .125 thick..It's for a air filter..No welding inside either!!!!No burn thru to clean up either!!!!OK whatever.3/32" Red SHARP!!!! NO balling before hand..1/16" 4043 filler..200 amps..PEDAL!!!Pics..Note the weld ends..That's how it should be..Couple more pics next post.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Couple more pics..The tungsten started out sharp and this is the end result..Sorry about the crappy pic..Camera had a hard time with it so close up..And that's the end.I get all the fun jobs......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:What did you use to cut those 45's?
Reply:Originally Posted by natesuehrWhat did you use to cut those 45's?
Reply:... Now THATS what you call an air-filter Nice work man[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:If I could weld  like that, I'd throw away my grinder keen!Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Awesome. Why so many amps? Could this have been done at 125 amps?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by PapaLionIf I could weld  like that, I'd throw away my grinder keen!
Reply:Originally Posted by zapsterI dunno..It was on the bench this AM when I got there with complete easy to understand instructions......zap!
Reply:Originally Posted by GambleAwesome. Why so many amps? Could this have been done at 125 amps?
Reply:Originally Posted by app-ironworksllcYou mean the kind that are drawn on a bar napkin?In crayon?
Reply:I've never used Red on a transformer (I would like to just to see for myself how well it works).But when i use it on my inverter i get really bad results almost no matter how run my machine. When im welding i can see the tip doing weird stuff. It usually gets a tiny ball (sometime balls) that always look like they are hanging on by a thread like a dew drop. and often it spits them off. but as soon as i kill the arc the tip settles to what looks like a decent tip. Do you ever see this when you use it? I ran out of 3/32 orange the other day and switched to red and the rest of my welds the whole day sucked (to my standards), it was like night and day.www.performancealuminumfabrication.com
Reply:Hit that dime with some Acetone Zap......shes looking grungy Nice job, as usual!!
Reply:Some damn impressive welds... something to strive for!JoeMiller 140 Autoset (2010)Miller Syncrowave 250 (1996)
Reply:BeautifulReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by Mick120I like some of the plans that chippies bring in.....
Reply:Originally Posted by DSWBy "chippies" I'm  guessing you mean carpenters or wood workers. I know you are on the underside of the world down there, but I didn't realize on top of driving on the opposite side of the road, and having water go down the drain the opposite way, you also swap the dimensions on 2x4's. Also thought you all used the darn metric system. A 4mm x 2 mm or even a 4cm x 2 cm board makes for mighty tiny drawings.
Reply:.I prefer Yamalube 2R at 32:1..
Reply:Must be the propane fumes that make you weld that way  Beautiful
Reply:Smooth as usual zap! Originally Posted by travisc454I've never used Red on a transformer (I would like to just to see for myself how well it works).But when i use it on my inverter i get really bad results almost no matter how run my machine. (snip)
Reply:Well that's where are you're going wrong. A clogging stick is known as a Glasgow Screw Driver
Reply:Zap. you always post good looking TIG welds.  I to was a little surprised on the initial amps but I believe understand your concept.  I have tried the same approach, but not at the high amps you employ.  I am not sure what my little 185 reduces to at partial pedal, but I am going to try and see how it goes...or how fast I will have to move the tungsten   Thanks for posting.GeezerPower Mig 255C185 TIGBlue 175 MIGRanger 8 Kohler 20HP1974 5K Lincoln/Wisconsin Powered (Cherry)Victor/Harris O/AK 487 Spool Gun
Reply:Great fit-up man, nice weld too.
GMT+8, 2025-12-26 17:39 , Processed in 0.095583 second(s), 18 queries .
