Trying to get on a pipeline and need some info on getting on. My rig is just about done ( 2010 chevy 2500hd 4x4, Lincoln SA200 short hood). What kind of test should I be expecting, What kind pay is considered good pipeline pay, Good companies to work for, Do you have to take a test on the job or at the companies office? Any tools may need,etc. Any info would be helpful.Last edited by Bamadee334; 08-21-2013 at 11:11 PM.
Reply:WOW you normally what to know all these things before you buy a truck and welder look around on here lots of info
Reply:Wow!! You guys have been a lot of help!!!
Reply:Originally Posted by Bamadee334Wow!! You guys have been a lot of help!!!
Reply:Not whining, just thought you guys were snubnosesing me because it was my first post.
Reply:not at all previous weld certs ? can you pass a 5g and 6g ?weld Xp? with out experience best bet would to go on as a hand (helper) learn the ropes then move upMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Hey if your wanting to pipeline. I suggest 2 things. First depending on your exp. Go get on a pipeline as a helper and turn into a sponge and soak up every god.damn thing you can for a year or so or go buy you a stick of 12" schedule 40 and practice your branch and bellhole test. Also get you a template for a 12" saddle and a pipefitters blue book and make it your bible.
Reply:Originally Posted by Bamadee334Not whining, just thought you guys were snubnosesing me because it was my first post.
Reply:Originally Posted by shovelonNo, it is because you did not prime the pump. Every piper knows that. You don't prime the pump, you run dry and fry the bearings. Then you got to start over.Care to start again? Nicely?
Reply:Originally Posted by RojodiabloI kinda like the way you put that!Bamadude- you will need to be able to pass a test of a 6-8" pipe, in a 6g position, 6010 root pass, and 7018 fill and cap as a minimum. This will include beveling your pipe properly, setting your pieces, tacks, and then weld up.As a single hand welder, you will use company equipment. It's always good to bring your own stuff, because if the company gives you a junk grinder, with a lousy wheel- your weld will show it. I recommend your own basic tools to test with at the least. You can always leave them in the truck if they supply you everything. Bring: Your own gloves. Face shield. Safety glasses. Welding hood. Wear steel toe boots. Long sleeves, cotton clothes. If you are trying to get on as a rig welder, then when you show up, YOU HAD BETTER BE SET UP AS YOUR OWN WELDING COMPANY. End of story. You should be ready to flame cut the pipe. Grind on a bevel. Weld the pipe. all by your self.Pay? This depends wildly on the area, the work, and what you are qualified to weld on. Say from $16 an hr for a low scale single hand welder working for the shop, to $25 an hr for a decent welder working for the shop. $30-35 for a top tier welder working for the shop.For a rig welder, from $300-500 a day.If you can not put down a very clean root pass???? Do not bother.
Reply:Weld up- as in weld it up. Not meaning weld it uphill.....And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Thanks guys for the info.
Reply:For your sake I hope you have some kind of experience with API 1104.There was a graduate from my school a few weeks ago who set his truck up as a rig and thought he was moving to North Dakota to be a pipeliner.He failed his branch "test" in school.. could never even get the saddle to fit properly. So Lord knows what the hell he's doing now. Probably sold the truck, or rented it out. |
