Mig Machine without gas
发表于 2021-8-31 23:29:14 | 显示全部楼层 |阅读模式
Hello What is the best welding machine with out gás? for use in auto body work.thanks
Reply:Lincoln Procore100 or 125www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Using Flux core for auto body work will be a messBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Originally Posted by killdozerd11Using Flux core for auto body work will be a mess
Reply:Not sure why you want to do auto body without gas, cost based?  I've found that it is worth spending a bit more to get a decent machine that does the job you need done.  I looked at buying a cheap box store flux core wire welder in the $300-500 range but ended up with a Millermatic 211.  It will do flux core but also does gas and SS and Alum.  I've had great results on thick and thin material using 75/25 gas.  The initial investment may be a bit higher, but you'll love the results and you'll also have a decent machine.
Reply:Miller has a current rebate program . The 211 is on it BUT it's  only until the end of August.Add a bottle of 75 / 25 and a roll of '' Easy Grind '' and you will be in heaven. Rebate    http://www.millerwelds.com/landing/build-with-blue/      Easy grind     https://weldingsupply.com/cgi-bin/ei...DEF:OR:130TF44
Reply:Terry gave me a roll of that easy grind wire ....Just waiting to try itgot some silicone bronze to do some of it with the tigBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Yeah i would spend the extra and go for a gas set up! I have done both FC and regular mig for autobody repair. and I agree with everyone else on here FC is too hot unless you are really experienced with sheetmetal welding..(not saying your not....lol for all I know you could be way better than I and I have been burning car bodies with a mig for ten years for a living) If you are looking for a good budget 110v mig I would seriously look into the hobart handler series of MIGs I used to own a handler 135 and loved it. I will admit though FC is awesome for welding doors and decklids shut on derby cars......lolMillermatic 30aMillermatic 210Miller thunderbolt 225 ac/dc/ccMiller HF15-1-wg tigLincoln ranger 10(honda powered)Cebora 175 mig Too damn many tools but oddly not enough......
GMT+8, 2025-12-26 17:44 , Processed in 0.195687 second(s), 18 queries .
