running 232 wire / SP 200
发表于 2021-8-31 23:29:13 | 显示全部楼层 |阅读模式
Has anyone ever ran 232 wire off a Lincoln SP 200?    I'm questioning whether it has enough gusto to do it.     My intentions would be to just run an LN 25 off it.    Does anyone know if theres a contactor switch on the machine to make the output hot all the time?   If not, I'd think I could jump something inside to keep it hot, huh?  Anyone see foresee any problems  with my idea.   If you haven't run 232 off one, I'd appreciate you guess or thoughts about it.
GMT+8, 2025-12-26 17:52 , Processed in 0.096840 second(s), 18 queries .
