Coolant Reservoir for My Racecar
发表于 2021-8-31 23:29:08 | 显示全部楼层 |阅读模式
I needed to replace the cheap plastic coolant reservoir in the trunk of my iceracer.  I cut a 16x24" rectangle of 10 gauge, bent it into a C, and then plasma cut it in half.  This seemed like a good idea at the time, to make sure the bends were exactly the same, but in hindsight, it probably took longer.  I found that the current limit of my metal brake is right around a 16" bend in 10ga aluminum.  More specifically, the limit is that the table the brake is built into isn't heavy enough ( ~400 lbs ) to stay on the ground, I had to put one foot on the table to try and hold it down ( didn't have any convenient ballast ).   Then I fit the two Cs together, welded it up, added the filler on top, and barb fitting for the hose.   I cleaned up the plasma cut edges with a flap wheel, and cleaned with acetone before welding.  No brushing.  It is not professionally-pretty, but it is water-tight and will probably outlast the rest of the car.  3/32 lanthanated sharp to start, eventually balled, #7 cup.  Settled on 3/32 4043 filler, after trying every size I have.  AC balance at 65%.  180 amps, wide-open to start and then feathering off.   I'm supposed to be racing today, but there's 10 feet of water all over the track __David Hillman
Reply:I like, but isn't 10gauge a little excessive?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Yup, but I have a ton of it.__David Hillman
Reply:What kind of racecar?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:The chassis is an '86 Toyota MR2.  The drivetrain is a 20 valve 4age and 5 speed out of some Japanese-market front-digger, that I modified for rear-wheel drive installation.  It's a dedicated iceracer, so 9 months of the year, it resembles a one ton paperweight.  Has about 220 races on it, or so.__David Hillman
GMT+8, 2025-12-26 17:38 , Processed in 0.264142 second(s), 18 queries .
