Couple of TIG equipment questions
发表于 2021-8-31 23:29:05 | 显示全部楼层 |阅读模式
Ok, first off, I have the Chicago Electric 165 amp TIG welder.  I've added a foot pedal to it, now I'm going to get rid of that HUGE torch head & mount a -17 torch to it.  I'm going to change the cable & gas line to a gas through power cable 25' long.Question 1:The covers I see listed for the 25' torch are only 22 to 22.5' long.  Is there a special reason for the covers being 3' short?  When these are installed which end is left uncovered - machine end or torch end?Question 2:Which is better for the hobbiest, Leather or Nylon?  Currently the 10' torch I have has a plastic tube that isn't very flexible.  In fact, I've already burned a hole in it about half way up.  Not sure how I did that, but it's there.Snaps, Velcro or Zipper are listed as how they close.  But what size do I need for the cable.  There won't be a gas line in it, just the power cable.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:machine side stays uncovered leather or nylon i do not run a cover on my gas thru power cables only on my water cooled setupsMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Originally Posted by MarkBall2Ok, first off, I have the Chicago Electric 165 amp TIG welder.  I've added a foot pedal to it, now I'm going to get rid of that HUGE torch head & mount a -17 torch to it.  I'm going to change the cable & gas line to a gas through power cable 25' long.Question 1:The covers I see listed for the 25' torch are only 22 to 22.5' long.  Is there a special reason for the covers being 3' short?  When these are installed which end is left uncovered - machine end or torch end?Question 2:Which is better for the hobbiest, Leather or Nylon?  Currently the 10' torch I have has a plastic tube that isn't very flexible.  In fact, I've already burned a hole in it about half way up.  Not sure how I did that, but it's there.Snaps, Velcro or Zipper are listed as how they close.  But what size do I need for the cable.  There won't be a gas line in it, just the power cable.
Reply:Usually only cover the multi line setup.  No real need otherwise.  eBay has a few leather ones.  Two different diameters IIRC.  I have the one with snaps.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
GMT+8, 2025-12-26 19:19 , Processed in 0.127178 second(s), 18 queries .
