layout help
发表于 2021-8-31 23:29:04 | 显示全部楼层 |阅读模式
can anybody post a picture of this layout so i can make sure im doing it right ? 400mm x 600mm rectangle from the center point of the rectangle make a 200mm square from the center point of that square make a 200mm square offset 45
Reply:Sounds like a rectangle, with a 8 point star in the middle.
Reply:like this? Attached Images
GMT+8, 2025-12-26 19:21 , Processed in 0.070197 second(s), 18 queries .
