Cool Tool of the Day, Pics
发表于 2021-8-31 23:28:57 | 显示全部楼层 |阅读模式
This is a spot to show off a tool or device that makes your life a little better. It can be any tool, machine, or device that you consider appropriate. The only stipulation is restrict posts to one tool once a day, so people have time to keep up with them and not run out of tools as fast.My first entry is a little C-clamp I have from my Ironworking days. It will move mountains an inch or so at a time. Attached ImagesMiller 250DXTD Cutmaster 100Duct TapeBFH
Reply:I appreciate your contribution, but lets try to keep this on topic. No self portraits.Miller 250DXTD Cutmaster 100Duct TapeBFH
Reply:I have one to keep hand rail from warping so much when you are welding an upright right in the middle.I think I saw a simular tool on this board a few years ago.  It works pretty slick.-Mike Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:thats a really useful looking tool you got there brainfarth. was it hard to modify the clamp to be like that?http://datingsidorsingel.com/
Reply:This is a 16 ton HF pipe bender I modified into a press brake.  I will bend 1/4" up to 10" wide. Attached Images
Reply:Naw.. I think I just mig welded it to the plate.  I've made half clamps outa crappy ones that break often...Common sense in an uncommon degree is what the world calls wisdom.
Reply:Very useful Idea Mike,  I know there will be one of those on my shelf tomorrow!I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:A ring roller I built - not my design. I mainly use it to arch tubing Attached ImagesFire!, Fire! Oh wait, that's my torch...Lincoln PT-225 TIGLincoln 175 MIG
Reply:The "F" bar.               Attracts cool cats. Rolls beams and plates.             Lifts and separates, also pinches.Attachment 11742Very handy for bringing the warped and twisted around.Torsion bar and two 1 1/4 bolts. Breaks all the rules, hasn't been broke yet.Last edited by denrep; 02-22-2009 at 07:45 PM.
Reply:We had one that looked like a big skeleton key.  Used it to "adjust" door hinges.  Nice tool.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Don't know how cool this one is, but it's something I use quite often when steel is being stubborn and won't do what I want/need it to do... If the BFH won't get it done, then I use this baby.... Comes in VERY handy sometimes.Here she is at use persuading some steel to get closer together... lolMy humble submission.GeneLast edited by GeneL74; 08-08-2007 at 11:33 PM.
Reply:Only people that like 'em more than weldors... dentists!
Reply:My submission for the day. Paragon, when you absolutely need it 2000 degrees. Attached ImagesMiller 250DXTD Cutmaster 100Duct TapeBFH
Reply:Hey Vipernut, I am digging that roller you have. Too bad my buddy just left the bearing business. I think I found a project, like I don't have enough of those.Miller 250DXTD Cutmaster 100Duct TapeBFH
Reply:Not to get off topic but, did you see that wild spider web on Vipernuts bench?!!!!! "Every choice you make will effect at least one other person"
Reply:Yeah, that was pretty sweet. I wonder if he rolled those on that bender he posted. Man I gotta get one of those.Miller 250DXTD Cutmaster 100Duct TapeBFH
Reply:hey vipernut im really loving that ring roller and the web you made. have you got the plans for the ring roller? id love to have a copy if you do.http://datingsidorsingel.com/
Reply:Count me in too!Jax
Reply:I've got this bending tool, it is fitted with multiple guides, a manual winch, is portable and is especially useful to relieve work related stress. City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by woodironmanNot to get off topic but, did you see that wild spider web on Vipernuts bench?!!!!!
Reply:Originally Posted by Blackcypress-EBHey Vipernut, I am digging that roller you have. Too bad my buddy just left the bearing business. I think I found a project, like I don't have enough of those.
Reply:Here it is:Attachment 11777Chop saw - 20"blade with 20hp motorThe coolest part of this saw, is that I can tell you about it!When moving this saw, I had pulled over the truck and was adjusting the tie downs. I paused to watch a mustang really crankin' it on. When the driver grabbed a gear, he lost it! The mustang crossed the center line and piled into the front of  my stopped flatbed; pushing it backwards.As the mustang was bailing into my truck; I just knew I was gonna get it! I didn't know if it would be by the  mustang, the truck, or, the saw. The open passenger door acted like a scoop, trapping me, yet protecting me. Fortunately no one was injured. Wiped out both vehicles and dropped the saw.Every time I use it, I can't help but think of that day.Last edited by denrep; 02-12-2009 at 01:53 AM.
Reply:My submission:This is a camshaft sprocket holding tool for a Subaru, I made it because the factory tool costs over $500. works like a champ. Holds the pulley by grabbing onto the 12 point hub and you can stick a 10mm allen bit in through the 3/4" square drive hole to break the bolt loose.Don't talk about it, Just do it!
Reply:The socket looks so clean I bet you could market it on Ebay for a good piece of change.Common sense in an uncommon degree is what the world calls wisdom.actually The socket is brand new from Harbor Freight. I bought a whole set of "wombo sized" sockets there for cheaper than one socket I could find anywhere else.Don't talk about it, Just do it!
Reply:Hope you all dont mind me bringing this back up, but I got plans to build this tube bender.  I got the 1.75" tube die and then I got a harbor freight hydro/air ram to bend with. I had to modify it a bit to make it work for mine, but it bends great. Plug it into air and watch the tube bend!
Reply:Originally Posted by fordmanHope you all dont mind me bringing this back up, but I got plans to build this tube bender.  I got the 1.75" tube die and then I got a harbor freight hydro/air ram to bend with. I had to modify it a bit to make it work for mine, but it bends great. Plug it into air and watch the tube bend!
Reply:Can you end me the plans? bob AT warnerknives DOT comAlso do you have a broader photo that show it in action? It is difficult to see how it works.
Reply:My new cool tool bender I finished a month ago.  I just got it painted last weekend, but don't have photos of that...  so here it is in the raw with WD-40 in case you did not get to see it before... Attached ImagesBuild a Barstool Racer at BarFlyRacers.com!
Reply:I just got it painted last weekend, but don't have photos of that... so here it is in the raw with WD-40 in case you did not get to see it before...
Reply:my favorite tool?  My 4lb hammer.  Zap tack it and with one surgical BAAAM!  Perfect!
Reply:Originally Posted by VicoorMy submission:This is a camshaft sprocket holding tool for a Subaru, I made it because the factory tool costs over $500. works like a champ. Holds the pulley by grabbing onto the 12 point hub and you can stick a 10mm allen bit in through the 3/4" square drive hole to break the bolt loose.
Reply:Often it seems like the best tool in my shop is the one I'm using at the moment, but this little 'bench dog', copied from the woodworkers, gets used almost every time I'm at the welding table.Once smack with a brass hammer and whatever is under the dog is held pretty securely to the bench top.  One smack on the vertical side and it's loose.  It also promotes a good ground when welding.  Also it's not too particular about the shape of the object it's holding.John Attached Images
Reply:Originally Posted by jwormanOften it seems like the best tool in my shop is the one I'm using at the moment, but this little 'bench dog', copied from the woodworkers, gets used almost every time I'm at the welding table.Once smack with a brass hammer and whatever is under the dog is held pretty securely to the bench top.  One smack on the vertical side and it's loose.  It also promotes a good ground when welding.  Also it's not too particular about the shape of the object it's holding.John
Reply:now THAT is intuitive. i have always thought of things to transfer from wood working to metal working like clamps, squares, tools, etc... but never thought of the bench dong. very nicely done.Later,Andy
Reply:Thanks all.  I have three on my bench and I have used them all.  They are just steel off of my scrap pile.  I mostly cut them out with a 4 X 6 bandsaw.  My saw isn't the Harbor Freight one, but it's very similar.  Mine came from Montgomery Ward.  Now that's old!  (about 25 years old).I have a row of holes about 6 inches apart across the front edge of my welding table.  I need to drill some more, further back.  More holes will make some layouts easier.  I probably ought to go nuts and drill a square matrix all over the table.I use these more than a welding finger, and I think the finger is a great tool.John
Reply:I am guessing from the pics1/2" round thru a 9/16 hole?Thanks for the great idea!
Reply:Ohmygosh - I can't believe I forgot the Weldingweb standard of measurement.  Sorry!The shaft is 1/2 and the arm is made from 3/8. Attached Images
Reply:Sorry I wasn't more specific, but I was basically wondering about the size of the whole in the workbench. Obviously its slightly larger. Maybe a 16th or a 3/64ths of an inch bigger? Sorry for the seemingly neverending questions, but I just thought that these little differences would make a big difference in the way it locks down. I know I am a pain, why cant I just try it and see!
Reply:Mark, not a problem on my end.  I couldn't remember, so I went out and measured.  The hole and the shaft is nominally 1/2"  My HF calipers say the shaft is .498 and the hole is .500.  I don't remember if I wallowed the holes out with a file.  I think they loosen up pretty quickly with use.  I've been using these for a couple of years and they still hold tight.John
Reply:Thank you John. I am definantly going to build some of these benchdog thingamajigs.
Reply:Hey, I couldn't help but bring this back. I really liked some of the tools this brought out and thought I could wrangle in some more contributions.This is my latest. I bought this thing for $20 and all it needed was a cord. It is like new. Unbelievable. Cuts like a champ. Attached ImagesMiller 250DXTD Cutmaster 100Duct TapeBFH
Reply:I just bought one too, but I paid list price Whattatool!Real world weldin.  When I grow up I want to be a tig weldor.
Reply:I got a small portable band saw like that from grizzly and it came with a stand so you can use it like a chop saw. It was half the price of a floor standing unit and works awesome for cutting random pieces like I need.found a small pictureonly issue is the vice is cheesy and it doesn't cut too straight
Reply:looks like it still needs a cord//
Reply:That bender is sweet!Learn to burn...........Lincoln Powermig 350 MpHobart AirForce 400
Reply:Tubing Bender turned out quite well... Where did you order the plans from?Godspeed,Charlton
Reply:Gotta love bridge clamps, I have had a few "follow me home" .Disclaimer; "I am just an a$$hole welder, don't take it personally ."
GMT+8, 2025-12-26 17:54 , Processed in 0.643105 second(s), 18 queries .
