Looking for perforated metal
发表于 2021-8-31 23:28:57 | 显示全部楼层 |阅读模式
I am looking to build some race mufflers, but am having trouble finding a source for perforated steel sheets.  Does anyone have a good source on this?  I am just looking for a small amount right now so I can make a couple of test mufflers.  Thanks for any help.
Reply:I would use expanded metal for glass pack mufflers.Last edited by nikodell; 01-17-2012 at 05:00 AM.
Reply:Originally Posted by nso123I am looking to build some race mufflers, but am having trouble finding a source for perforated steel sheets.  Does anyone have a good source on this?  I am just looking for a small amount right now so I can make a couple of test mufflers.  Thanks for any help.
Reply:Originally Posted by ECAVETry mcmastercarr.comIt will be pricey, but you can get it pretty fast.
Reply:McNichols is another source that will probably be less expensive than McMaster.  I have dealt with them before - I'm sure they have a website but I've always used the catalogs and called in the orders.  Their specialties are expanded metals, grip strut, perforated metals, screen cloth - all of that type of material.
Reply:2nd on McNichols.  Assuming you want stainless:http://www.mcnichols.com/products/pe...ainless-steel/If you're going to be using perf'ed tubes, you can buy those ready-made:https://www.google.com/search?&q=per...ainless%20tube
Reply:What is it for? Tube diameter? Perforation density?
Reply:I've built some mufflers for my bikes and quads.. here is what i used and its cheap can be got at all lowes... i would advise wrapping the tube you make from the mesh with metal screen and pack the tube accordingly. Hope it helps.http://www.lowes.com/pd_157336-205-8...rds&facetInfo=Owner G&S Mobile Welding & Millwright Services, LLCSpencerville, Ohio Adult Ed. Instructor at Apollo Career Center Lima, Ohio
Reply:Not dense enough... for any kind of proper attenuation you want to be in the 40-50% perforation density, that screen is in the 70% range.
Reply:It is for a Limited Street drag car.  We will be making anywhere between 1100 and 1500 horsepower, depending on which engine we decide to use.  We are required to run mufflers, but sound attenuation is not really an issue, as you can only do so much to quieten one of these cars down.  It will be a 4 inch inside diameter with one engine, and 5 inch if we use the other.  We basically just have to pass visual inspection.
Reply:depending on where your located there are much cheeper alternitives than mcnicols.   if your in CA for some reason try Cal-perf in fresno.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:http://www.diamondman.com/perforated-metalhttp://www.marcospecialtysteel.com/p...ted-metal.htmlLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:For small amounts of expanded or perforated metal, try Amazon.com.  Yes, Amazon.com.  They have outside vendors for raw materials using Amazon to sell their products.Last time I needed a half sheet of 304 Stainless 11 gauge expanded metal, I ordered it through amazon.com.  Shipping was free and delivery was prompt.  Pricing was the same per sq ft as my local steel supplier.  I shop locally for most everything.  But my local steel supplier didn't have a drop, and I didn't need a whole sheet for the project.  SS expanded metal is too expensive to buy extra material if there's another option.Hope this helps...Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:It would help if you posted location. Did you want to roll it round ??? maybe a local fabricator or sheet metal shop may help.
Reply:Direct Metals www.directmetals.comwww.somethingdifferentftw.blogspot.com
Reply:Gerrard Daniel Worldwide is another source. Check your local sheetmetal shops as they will likely have stock or offcuts. Any specialty metal supply houses near you?Thermal Arc Fabricator 2101970 Lincoln RedfaceMiller 150 STLStill need a Syncrowave and a plasma and a milling machine and a lathe and a bigger shop and a....
Reply:Thanks guys, Amazon was the trick for a small amount, and I got free shipping.  I will post up pics as soon as I get the mufflers built.
Reply:You got a link to what you got off Amazon as I'm looking at getting some too?
Reply:This is what I found.  They have other options too.http://www.amazon.com/gp/product/B00...00_i00_details
Reply:Mcmaster Carr sells perf plate in several different sizes and hole patterns; I have ordered from them in the past and they were always good.http://www.mcmaster.com/#perforated-metal/=fw6y5k
GMT+8, 2025-12-26 17:54 , Processed in 0.094737 second(s), 18 queries .
