tig time
发表于 2021-8-31 23:28:57 | 显示全部楼层 |阅读模式
ok was playing around with a tig machine my buddy let me use it because i said I wanted to learn to tig. Here's a photo of some of the beads I ran tips and pointers are welcome.Miller maxstar 150 set at 70 amps 1/8 inch plate.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:You have been here long enough to know to GET RID OF THE #@!&&&^%$ MILLSCALE!!!!!Geesh.Do that and try again....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:x2, CLEAN YOUR METAL and work on being a little more consistent. Other than that, you're off to a really good start [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Originally Posted by zapsterYou have been here long enough to know to GET RID OF THE #@!&&&^%$ MILLSCALE!!!!!Geesh.Do that and try again....zap!
Reply:OK Zap I have been doing some reading on mill scale removal what would you say is the best way to remove it?Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Any way... Abrasive pad, flap wheel, grinder... Essentially, by any means necessary.
Reply:Also, at the end of your weld, slowly let off the accelerator, by that I mean, slowly let off the pedal , it should help with the dimples at the ends of your beads, do this to prevent crater cracks.
Reply:Originally Posted by SteelwillOK Zap I have been doing some reading on mill scale removal what would you say is the best way to remove it?
Reply:Originally Posted by VinnieWhat did your reading say???V
Reply:Disc grinder....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:X3 clean metal,clean weld . X2 on slow decelleration at the end if the bead, hold the nozzle over the puddle while your post flow is running. This will prevent cracks by protecting the puddle as it cools. I'd say turn your amps up a little and don't feed so much rod in and the bead should smooth out. Keep it up! I lovve tig
Reply:clean metal first.....then while your running a bead get into a rythum....get a puddle formed, then dip (in the same spot), move forward, , then dip, and repeat. Ounce the metal warms up either let off the heat with your peddle of move a little faster,  also watch your toes and make sure each dip fills enough before moving forwardLincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Was able to get a little more practice time more photosWill   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Better!!  Keep under the hood as much as you can!AEAD 200LE, Lincoln precision tig 185, Millermatic 251, Spectrum 625 extreme, Victor torch , Smithy 1220LTD. and  Do all C-4 band saw ,  Always adding.
Reply:Looks like you may have cleaned the rust off that pipe on a bench grinder and not got it quite clean enough. Did your arc turn green while welding this? I know i've had that problem when practing TIG on scrap metal and not getting it clean enough.Last edited by Gump; 01-22-2012 at 08:48 PM.Reason: I can't spellSafety 3rdGump
Reply:Originally Posted by GumpLooks like you may have cleaned the rust off that pipe on a bench grinder and not got it quite clean enough. Did your arc turn green while welding this? I know i've had that problem when practing TIG on scrap metal and not getting it clean enough.
Reply:Looking good so far. I usually wipe my material down with acitone after I grind the scale off to clean off the dust. Just my .02 worth.Century Powermate 100 ( my first welder)Lincoln Precision TIG 185
GMT+8, 2025-12-26 17:55 , Processed in 0.076079 second(s), 18 queries .
