Plasma cutting guide.
发表于 2021-8-31 23:28:54 | 显示全部楼层 |阅读模式
I whipped up this little fixture to work with my doggie wheelchair plasma attachment. Lay the plastic "target in the trough and line the line up with the cut line. Clamp down fixture. Lift out plastic and cut. Works pretty good. Attached Images
Reply:Cool idea, i've thought about making something like that.
Reply:That should help a lot on time setting up to cut and accuracy .
Reply:Good idea! I made for using with my Miller plasma cutter, but it is not as a neat setup as yours is. I just made a short one from bed frame angle iron.Rodney                                   The blessing of the Lord makes one rich, And He adds no sorrow with it.'  Proverbs 10:22 NKJV
GMT+8, 2025-12-26 17:55 , Processed in 0.101534 second(s), 18 queries .
