Regulator not adjusting hose pressure?? HELP!!
发表于 2021-8-31 23:28:50 | 显示全部楼层 |阅读模式
I am new to this forum and new to welding.  I have an oxy ace torch setup with Victor regulators.  For some reason when I open the tank valve on either tank (oxy or ace) the hose pressure can not be adjusted with the hose valve.  Hose pressure just continues to go up until the pressure is so high that the over pressure release valve opens and I can hear the air (or gas) coming out of the regulator.  This happens no matter what I do to the hose valve.  I turn it all the way to the right; pressure keeps going up.  I turn it all the way to the left; same thing. What is really strange is that as far as I know they both (oxy and ace regulators) started doing this at the same time.  Does anybody have any idea what is going on here?Thanks in advance
Reply:Sounds like blown diaphragms in the regsExperience is something you get right after you need it
Reply:Bad diaphragms most LWS can send them off or replace the diaphragms in house I just get the kits from the LWS and put them in myself (saves a few bucks...)Millermatic 30aMillermatic 210Miller thunderbolt 225 ac/dc/ccMiller HF15-1-wg tigLincoln ranger 10(honda powered)Cebora 175 mig Too damn many tools but oddly not enough......
Reply:Originally Posted by cowboy181dBad diaphragms most LWS can send them off or replace the diaphragms in house I just get the kits from the LWS and put them in myself (saves a few bucks...)
Reply:Ok, thanks fellas
GMT+8, 2025-12-26 18:03 , Processed in 0.097778 second(s), 18 queries .
