Mounting a bed to a new truck
发表于 2021-8-31 23:28:50 | 显示全部楼层 |阅读模式
What is the best type of wood to use to put between the sub frame of the body and the frame of the truck that its being mounted to.
Reply:dark oak.or pressure treated.G
Reply:What type of truck / application are you talking about?  As always, a photo goes a long way to explaining the situation.I don't think wood is used anywhere anymore in a truck manufacture.  In your title "new truck" I'm assuming its a brand new truck... answer = no wood anyplace.  (Use steel or a polymer / rubber / plastic material where isolation is required.).
Reply:I believe most heavy duty semi trailers use Apitong. I would NOT use pressure treated. I found out the difficult way that it is very corrosive. (Look in the "off topic" area for my "roof on the conex" thread.)"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:uhmw, wont ever rot or break apart.tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Most new installations are steel to steel. Older trucks had rivets and bends in the frame that made some type of spacer necessary, most newer trucks have a flat frame rail.
Reply:Originally Posted by leightrepairsMost new installations are steel to steel. Older trucks had rivets and bends in the frame that made some type of spacer necessary, most newer trucks have a flat frame rail.
Reply:I work at an Automotive test facility where a major truck builder is a customer.  When we install beds on their trucks they have us use oak in between truck and bed.  Most every truck I work on has straight frame rails.
Reply:I would use Ultra High Molecular Weight Plastic as a first choice the the entire rear end of my Murray lowbed carried 60,000 lbs on about 2 square feet of it.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I've built several beds and always used steel and never had any problems. I always worried about shrinkage in the wood.
Reply:I would add a vote for UHMW.  This is only if you think you need a buffer for some reason.  I would be just as happy with steel on steel and plenty of bolts.
GMT+8, 2025-12-26 17:55 , Processed in 0.093478 second(s), 18 queries .
