Just finished my welding table
发表于 2021-8-31 23:28:49 | 显示全部楼层 |阅读模式
Finally off the garage floor3' x5' x 1/2" top plate. 36" tall.2" .120 wall square tube. Two side pieces are reciever hitch material for mounting the vice and bench grinder. (will finish that up this weekend). Casters and adjustable leveling feet (1" x 2" bolts) Miller Synchrowave 180 SDLincoln PowerMig 255Hypertherm Powermax 45Torchmate 2x2Victor O/A
Reply:Hell yeah, looks good!Welding/Fab Pics: www.UtahWeld.com
Reply:Now thats a nice table[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Me Likey!"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:That is a nice tableBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:good looking table dude. arent those casters a little undersized, though?Go Cards!!!!!
Reply:Originally Posted by Cliff Lodesgood looking table dude. arent those casters a little undersized, though?
Reply:I like it! ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Very nice!!
Reply:Superb!
Reply:nice!www.thefusionsolution.com
Reply:Looks clean. I need one.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Nice looking table neighbor!
Reply:That's a nice looking table you did there, thumbs up to you. really like the mobility of it. Only test i can think of right now is the rolling test. Give a real big push an see if you can roll it to me......VGJ.In the words of the great philosopher Quagmire.Gigedy Gigedy Gigedy Gigidey Goo.
Reply:I have those same wheels on my cnc plasma, which is about the same weight. They have been on there about three years and still work fine. Good looking table.Ian TannerKawasaki KX450 and many other fine tools
Reply:Love the use of the KISS Method. As for the casters. you're combined weight rating is 1300 lbs for the 4 casters. You'll be fine on the weight. you're at less than half that weight. and I'm sure that you won't be putting another 600 lbs of weight on that table while it's moving. and like you said, the feet support the weight when it's not moving.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:saweeeeeeeeeeeet table man
Reply:PerfectDave ReberWadsworth Ohio
Reply:Elegantly simple.  Nice job.  The only thing I would suggest is to round the corners.Miller Dynasty 200 DXBuildPro TMA52238 (38" x 22")Miller MP-10 & Jackson Nexgen EQC20 Ton Press & Swag HD Press Brake
Reply:Thanks guys. I will be adding a shelf to the bottom horizontal tubes, and mounts for my grinder and vise storage. And I will be adding a couple of drawers for my magnets, squares, clamps, ect.Miller Synchrowave 180 SDLincoln PowerMig 255Hypertherm Powermax 45Torchmate 2x2Victor O/A
Reply:Great design! I really like adj. feet/ caster idea. I will be using that!!!!!
Reply:Just finished the grinder and vice mounts. They slide into the two pieces of hitch tube on either end of the table, and can be moved to all 4 corners.Thats my next project sitting on the table Attached ImagesMiller Synchrowave 180 SDLincoln PowerMig 255Hypertherm Powermax 45Torchmate 2x2Victor O/A
Reply:How much did you pay for your top? For a 3/8 they wanted $260!
Reply:nice where did you get the adj. feet
Reply:Nice table!Very nice table. The next project will be cool also.Miller Diversion 180Lincoln Mig Pak 5000 HDHypertherm 45Uni-Spotter Stud WelderOxy Set-up with Harris TorchMiller 30FX Arc StationMiller Elite - Hockey Canada Helmet
Reply:What did you use for leveling feet??
Reply:I get my leveling feet at JW Winco in Wisconsin.http://www.jwwinco.com/
Reply:Very nice!LarryMiller XMT 304 CC/CVSyncrowave 180 SDLincoln PowerMig 255XTTermalDynamics 52Lincoln 305GComlpete machine shop to back it up
Reply:Originally Posted by pyroracing85How much did you pay for your top? For a 3/8 they wanted $260!
Reply:Originally Posted by ed macnice where did you get the adj. feet
Reply:very nice job Legacy. now inflict some abuse on it 225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:Table is nice but where'd you get the stool? That's a nice one!200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:Originally Posted by bert the welderTable is nice but where'd you get the stool? That's a nice one!
Reply:Looks great. One question...Why in the first pic do your reciver tube ends square up with the long tubes, and in the second to last pic, the reciver tubes hang out about 3" (from a side view)?~RocklandMillermatic 211
Reply:Originally Posted by rocklandLooks great. One question...Why in the first pic do your reciver tube ends square up with the long tubes, and in the second to last pic, the reciver tubes hang out about 3" (from a side view)?
Reply:Very nicely done, looks great!
Reply:Originally Posted by LegacyThe reciever tubes do square up to the long tubes. The legs sit on the inside corner of those two tubes giving it the illusion that they are offset.
Reply:nice//round off the corners before ya hurtcherself...
Reply:Originally Posted by killdozerd11I'm going to do the receiver tube thing with the bench i just got kind of done with for the moment Other things to do right now By the way i live in Hemet actually i am closer to wichester i go through there all the time
Reply:Originally Posted by weldbeadnice//round off the corners before ya hurtcherself...
GMT+8, 2025-12-26 17:54 , Processed in 0.450950 second(s), 18 queries .
