查看: 13|回复: 0
Goes to show, you can get a bad one of anything
发表于 2021-8-31 23:28:48 | 显示全部楼层 |阅读模式
Brand new, right out of the box.
Reply:gotta resize the pic, all i see if your fingers and a 1/4 of the bearing.ESAB MigMaster 275Miller Econotwin HFMiller Syncrowave 250
Reply:I see pitted rollers, NFGDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:If they kept one roller out of each bearing they could make an extra bearing pretty cheaply.  Mac
Reply:Thats where you put the extra grease.CERTIFICATIONS:7018M- H.V.O10718M- H.V.O11018M- H.V.O9N10- H.V.O71T-1-HYM- H.O.V100S1 PULSE ARC 0,035- H.O.V100S1 PULSE ARC 0.045- H.O.VER70S-3 PULSE ARC 0.035 H.O.VER70S-3 PULSE ARC 0.045 H.O.VER5554- H.O.V
Reply:Thats a muffler bearing, the exhaust gas excapes there.
Reply:wow napa too!!!Esab Multimaster 260Esab Caddy160IEsab 161 STLESAB powercut 650Esab 220i tigLincoln Precision Tig 225Lincoln IdealArc 250INE SKYLINE 1500Klutch 140iMEASURE TWICE IS FOR MORONS
Reply:I work for a major bearing manufacturer that is a competitor to SKF...... I won't bash SKF, partly because I have no loyalty to my company, and because this happens at every manufacturer.  Has nothing to do with Napa since Napa doesn't do quality inspections at the same level as SKF is supposed to.   It happens...more than it should.  its one of the more common bearing defects I hear about from my customers.   I'd guesstimate it happens maybe once in a few hundred thousand parts...but we hear about it for sure.   Take it back to Napa,  they'll get you a new one.   also, i recommend a manicure  haha
Reply:hahahaLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:george castanzas got nothing on your hand modeling abilities
Reply:i have seen quite a few oil filters with NO internal thread cut into them. Now thats QC!HTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:the picture on the box is wrong also.
Reply:Originally Posted by citizen smithgeorge castanzas got nothing on your hand modeling abilities
Reply:I was talking about my hands not the bearing  I always tell everyone there is not a brand or manufacturer or part that I havent gotten a bad one right out of the box. They are all made by us humans afterall.
Reply:Put a carrier bearing in my friends kids truck and a few days later he comes in and the spot welds between the bracket and the bearing hanger all broke .Out of six spot welds only two had penetrated enough to be called welds and they were the diameter of a pencil lead  QC at it's finest I guess as long as the welds held to get out of the factory they were goodBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:No problem, pull one roller out from the opposite side to even it out and it is good to go.
Reply:Give me a moment to get my bearings straight. Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Napa is crappa, no doubt, but I don't expect chink QC from SKF...poop happens everywhere nowadays. First they , then they  Maybe you can squeeze them for a spare, too When a welder tells you to "stick it", what do they really mean?"In a time of universal deceit, telling the truth is a revolutionary act." - George Orwell
Reply:Put one from the old bearing in there.
Reply:Originally Posted by Titan Upthe picture on the box is wrong also.
Reply:Bearston, your dragging knuckles are showing.200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:Originally Posted by NickoliThe picture on the box is showing the bearing represented inside the bearing race!  To me the picture on the box is correct based on the part in CarlH's hand.
Reply:Originally Posted by Malave16Put one from the old bearing in there.
GMT+8, 2025-12-26 18:03 , Processed in 0.104755 second(s), 18 queries .
