Cargo Control
发表于 2021-8-31 23:28:48 | 显示全部楼层 |阅读模式
This has been a project that's been ongoing while the work on the trailer progressed.  It was done on rain days, or real cold days.  I was able to finish it up today while waiting for partsA full set of 4" cargo strap winches, with the unique-one of a kind Uranis Inc. Modifications. These are the usual weld-on winches, but I will never know exactly where I'll need a strap for hauling various sizes of round bales.  I need winches that can be temporarily attached anywhere along the side rail on the trailer.  And I don't like the commercially available ones...they're cheeeeeezy.  And I don't want to weld a track onto the side rail, it can warp the rail.3/4 flat stock was slotted, then an angle milled to match the shape of the channel the side rail is made ofBolt holes were then cutAnd the welding began.  This is Lincoln Excalibur 5/32 at mid range somewhere around 160amps DC using the Ranger machine.  The Ranger has sweet arc characteristics, and the Excalibur is phenominal.  It's a better rod/machine combination than I am a welderIf you're familiar with the shape of channel, you'll see why all the fancy milling had to be.  The winch lip will perfectly match the channel lip, and the set bolts will meet the channel surface at a nice 90 degree angle, which makes them very secure.  I didn't bother with the jamb nuts for the demo pics, but they'll be added before I hit the road.Installed on the side railHow it attaches behind the side rail.Build a mudflap hanger assembly tomorrow..........WHILE I'M STILL WAITING ON PARTS"Any day above ground is a good day"http://www.farmersamm.com/
Reply:are you going to have any issues with the strap rubbing on the rail? Did you build it that way to minimize the tortional stresses of having it mounted horizontally? (sticking out form the rail as opposed to down from the rail)There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:the excess strap is usually folded under the rub point which protects the strap and keeps the tail from flapping. B-E-A-U-tiful example of stick welding there.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:That's a pretty bead Samm. Nice work. Do you plan on only installing them as you use them, or will they ride around on the trailer all the time?I'd be scared of them vibrating loose and falling off. With the strap in place, Obviously it will work dandy, and they can't go anywhere.
Reply:My only thoughts are you still going to have to place them between the cross members?   I have a sliding track system on my F-800 and its nice for the straps but it does make using chains that much more difficult.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Great work.We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:Sambo, never knew you were into bondage...Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:Dang... if it's worth doing... it's worth over doing. Your right the commercial units appear a bit weak. I dug up a reference picture for comparison. Any reason you didn't just drill and tap the holes? Attached Images
Reply:Are you gonna weld/ or have you welded, the inside edge? I'd be worried about them if you don't.Ian TannerKawasaki KX450 and many other fine tools
Reply:Sam , you sure seem to have the Lincoln stick dialed in, great thouhgt on the design and better than sticking out away from the truck.      Do me a favor? PM me and explain to me how you put the text into the pictures or between pictures, when I post I would like to be able to explain the individual pictures some. Thanks."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Thanks for the replies, I like to read them, it's cool stuff these forums.Some of the questions...............1.  I am limited to the spaces between the crossmembers for instalation, but it's about 2" of "dead" space as the junior I beams have 2" flanges2.  I've never had much luck with taping mild steel when it has to take a lot of torque, the threads tend to distort too much.  But on the other hand I'm sure I've ruined some of the mechanical/metalurgical properties of the nuts when I weld them on.  It's sort of a Catch 22  (for anyone welding nuts like this, it's a good idea to do the weld while the bolt is in the nut, this helps to protect the nut from distortion, you can spray the threads with anti spatter to protect the threads, also...use the same bolt for all welds because the heat will probably affect it so it'll be a throwaway when you're finished)3.  It would be almost impossible to properly weld the inside section of the lip.  The lip is an exact fit to the channel it's mounted on.  I suppose you could bevel the space between the bolt holes, but if your weld in any way protruded into the machined area it wouldn't fit the trailer.  Also, a good weld will resist force in any direction tension/compression/shear/and pullout.  In a design like this, the force is concentrated at the root of the angle, not on the edge of the lip.  It's why the exact fit was needed.  The weld also wraps around the sides of the tab, this should give adequate reinforcement."Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-26 17:54 , Processed in 0.099017 second(s), 18 queries .
