Any ideas on welding leads for service truck
发表于 2021-8-31 23:28:47 | 显示全部楼层 |阅读模式
Well my new truck came with both leads in the bed, I am going to build your basic racks that you see on all the welding trucks, just plate with pipe to wrap around, I have a box that I am going to make a frame to bolt everything toThe problem is I need a way to protect them from theft without it being to painful to remove each time, I thought about a hinged lid that folds down that could double as a wire brush and chipping hammer holder but I have never seen them you guys have any ideas
Reply:Ive seen ironworkers wrap a steel sling through everything a couple times and lock it. Makes it a pain to unravel. still possible to steal, but more of a hassle. you could make cover to shroud the whole wraped up lead holder that secures with a lock..
Reply:How about building a cabinet around the leads with a door that you can lock up tight!AEAD 200LE, Lincoln precision tig 185, Millermatic 251, Spectrum 625 extreme, Victor torch , Smithy 1220LTD. and  Do all C-4 band saw ,  Always adding.
Reply:3 or 4 Ft Greenly or Delta Gang Box standing on end. Door now swings sideways, been wanting to do one with the torch bottles (I have the small ones) and welding reels inside."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Im not a huge fan of this particular look, but its a thought.. Looks like the dimond plate is locked around the reels. Must be a hinge in there somewhere. Attached Images
Reply:Originally Posted by kolot3 or 4 Ft Greenly or Delta Gang Box standing on end. Door now swings sideways, been wanting to do one with the torch bottles (I have the small ones) and welding reels inside.
Reply:No pictures, something I have thought about doing but haven't gotten to it."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Put a set of TIDWELD reels inside the box some where.  They are the smallest reels you can buy.  I love mine.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
GMT+8, 2025-12-26 17:54 , Processed in 0.089695 second(s), 18 queries .
