Nothing like a crappy cell phone pic.......
发表于 2021-8-31 23:28:47 | 显示全部楼层 |阅读模式
.....and a few thousand inch and a half on three skip weld to pass the day. Attached ImagesHeavy Metal Fabricationhttp://heavymetalfabrication.comhttps://www.facebook.com/heavymetalfabrication
Reply:How do you space them?Per mark the material?
Reply:usually you use a soap stone and mark it center to center. 2"-12" welds you would mark on the 11" and the 1" every foot.CERTIFICATIONS:7018M- H.V.O10718M- H.V.O11018M- H.V.O9N10- H.V.O71T-1-HYM- H.O.V100S1 PULSE ARC 0,035- H.O.V100S1 PULSE ARC 0.045- H.O.VER70S-3 PULSE ARC 0.035 H.O.VER70S-3 PULSE ARC 0.045 H.O.VER5554- H.O.V
Reply:I used a memory stick and a paint pen. You put a tack at the end of each mark then run your welds into it so it is easy to see where to stop.Heavy Metal Fabricationhttp://heavymetalfabrication.comhttps://www.facebook.com/heavymetalfabrication
Reply:how bout a pic of the entire piece?Weldanpower 225 G7Ironworkers Local #24
Reply:Sorry, this is all I have. They were great big fan cowlings.Heavy Metal Fabricationhttp://heavymetalfabrication.comhttps://www.facebook.com/heavymetalfabrication
GMT+8, 2025-12-26 17:54 , Processed in 0.094299 second(s), 18 queries .
