sp175t or migpak180??
发表于 2021-8-31 23:28:43 | 显示全部楼层 |阅读模式
newbie here,the sp175t requires gas, the migpak 180 does not.which lincoln welder would you guys recommend here?which one is better? would the sp175t be better since it needs gas to weld.thanks in advance.
Reply:Hey abe,You already posted this question on another thread. You were given the answer by member Broccoli1. Do your own homework...... you may LEARN something.DennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:No I did not ask this question, my previous question was different. This question is simply asking which of the two is better.
Reply:My understanding is the newer 180 amp unit contains Lincoln's Diamond Core choke design. Assuming this is true I'd go with the 180 over the 175. I use to own a Lincoln SP 175 Plus, and currently own a Lincoln PowerMIG 180C. The Diamond Core choke design in the 180C produces a cleaner arc and better weld puddle wet out then the choke design that was used in the SP 175 Plus.ESAB Migmaster 250 Hobart Ironman 230Multimatic 215TWECO Fabricator 181i & 211iHH125EZ - nice little fluxcore only unitMaxstar 150 STH - very nice
Reply:Originally Posted by DanMy understanding is the newer 180 amp unit contains Lincoln's Diamond Core choke design. Assuming this is true I'd go with the 180 over the 175. I use to own a Lincoln SP 175 Plus, and currently own a Lincoln PowerMIG 180C. The Diamond Core choke design in the 180C produces a cleaner arc and better weld puddle wet out then the choke design that was used in the SP 175 Plus.
Reply:Originally Posted by Brand XI am not sure that is totally true. Puddle wet-out maybe, but my first SP-175 plus had a cleaner arc then any 180c I have used. The 175 plus would make about the nicest little  beads on 16ga mild steel tubing. I wish I still had that first one.
Reply:I guess your question maybe different but the answer is the same. Either machine will weld with gas or no gas. The Mig Pak 180 does not have the diamond core tech so I think there performance would be similar.
Reply:Originally Posted by DanI never played with the SP 175 Plus on thin auto ga sheet metal: however, I have with the 180C (.023 wire). I think you might like the 180C  for this application. If you take the time to play with the voltage and wire speed dials, you can get the arc dialed in to be as soft or even slightly softer then what a HH 140 produces.A 180 amp unit that I really like on 16 ga (.023 wire) is the HH 187. It produces a very tight clean arc with very good weld puddle wet out.
Reply:Originally Posted by abrahamlincolnnewbie here,the sp175t requires gas, the migpak 180 does not.which lincoln welder would you guys recommend here?which one is better? would the sp175t be better since it needs gas to weld.thanks in advance.
Reply:Well, after researching this forum i have a better understanding of how these machines can be set up to weld on different metals and thickness.also brand x has a good point in dialing in the right arc settings for thinner steel.good info herethanks guys.
Reply:Originally Posted by Jay OI guess your question maybe different but the answer is the same. Either machine will weld with gas or no gas. The Mig Pak 180 does not have the diamond core tech so I think there performance would be similar.
Reply:Abraham,A third option to consider over both of the Lincoln units you are struggling to decide between, would be a Hobart Handler 187. The Handler 187 is a very good solid wire and self shielded fluxcore wire unit on mild steel. One reason I'd go with the Handler 187 over the two Lincoln units you are considering, is the fact that the Handler 187 offers 7 voltage tap selections; whereas, the Lincoln units offer 5.ESAB Migmaster 250 Hobart Ironman 230Multimatic 215TWECO Fabricator 181i & 211iHH125EZ - nice little fluxcore only unitMaxstar 150 STH - very nice
Reply:Originally Posted by yorkiepapHey abe,You already posted this question on another thread. You were given the answer by member Broccoli1. Do your own homework...... you may LEARN something.Denny
GMT+8, 2025-12-26 21:29 , Processed in 0.072222 second(s), 18 queries .
