To skip weld or fully weld
发表于 2021-8-31 23:28:41 | 显示全部楼层 |阅读模式
Good evening everyone!!So, I'm building a BBQ trailer... The tongue sticks out 4' in front of the frame and I've decided to run a stiffener made from flat stock under the full lenght of the tongue...Question: Should I fully weld this out? I'm thinking it'd be more rigid if welded 100%, but it would have more "flex" if I only skip welded it, and might be longer lasting. I'm thinking of skip welding for the application, but I thought I'd ask here, first. What says WW? Thanks in advance, guys [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:pictures of your joint design would help alotLincoln pro core 125 14''chop saw7 inch grinder,2-4.5 inch grinders,electric die grinder.Half inch drillAnd alot of hand tools
Reply:It's a fillet weld...[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Lanse, when will you learn THAT you are your own best critique/advisor ?
Reply:Skip, if a weld cracks at some point it will have a place to stop instead of traveling all the way down the tongue.Miller Dynasty 200DXMiller 252 Miller 250xMiller Syncrowave 250Miller AEAD200 LegendMiller 375 Xtreme plasmaLincoln WeldPak 100Victor O/A
Reply:I vote skip weld it...But I realize that a tongue stiffener on an 800 pound BBQ trailer is probably overkill anyway, and either method would work...thanks for the reply [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Eh overkill is good. Overkill never fails.Hobart Stickmate LX235AC/160DCRanger 305GVictor 315 O/A rigHope to acquire in the next couple of years: Hypertherm PM45 and Dynasty 200DX
Reply:Originally Posted by JD955SCEh overkill is good. Overkill never fails.
Reply:This is where an engineering degree would come in handy. I skip weld a lot of things, because it is easy to over weld something. I try to have my stops in the center of the weld. Because the crater is the weakest part of the weld. I have also used caulking between the welds before painting so water doesn't get under and start rusting. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by LanseGood evening everyone!!So, I'm building a BBQ trailer... The tongue sticks out 4' in front of the frame and I've decided to run a stiffener made from flat stock under the full lenght of the tongue...Question: Should I fully weld this out? I'm thinking it'd be more rigid if welded 100%, but it would have more "flex" if I only skip welded it, and might be longer lasting. I'm thinking of skip welding for the application, but I thought I'd ask here, first. What says WW? Thanks in advance, guys
Reply:CEP, I was taught to do the same thing.  a couple of years ago I posted a picture of a crater in the center and i really got my chops busted by some.  I do it a lot on thinner metal where when you get to the edge after welding a bead the edge doesn't fall out on you.  I also was taught to always start on the edge and never stop on the edge.  if you need to carry to the edge, then don't.  save an inch and then go from the edge to the stop.  It looks better and chances are if you are running hot then you don't leave a wash or crater at the edge to create a fault.  There are exceptions to the rule like when you are weld vertical.Last edited by Scott Young; 09-13-2013 at 10:39 AM.
Reply:a full weld will create more stress and warpage.  Skip weld it.  it doesn't take that long to draw out your pattern.  I like to alternate on each side though I have seen it paired on each side.  The engineer had his reason I guess for pairing.  He did it several times.  I don't know what pairing would do versus alternating, but to me alternating seems stronger.
Reply:Scott it is a lot easier when following a engineer's drawings, or a WPS. Takes a lot of the guess work out of it for us low life welders.  Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by CEPScott it is a lot easier when following a engineer's drawings, or a WPS. Takes a lot of the guess work out of it for us low life welders.
Reply:Ok Lanse.Let's see your WPS!Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Just a question here guys. How could a piece of flat stock stiffen the tongue? If you just weld it under, it isn't that effective so I guess we are talking about some other way? I just can't visualize it.
Reply:Originally Posted by Pete.S.Just a question here guys. How could a piece of flat stock stiffen the tongue? If you just weld it under, it isn't that effective so I guess we are talking about some other way? I just can't visualize it.
Reply:Bracing the bottom corners with full length angle iron would be better yet....Miller Dynasty 200DXMiller 252 Miller 250xMiller Syncrowave 250Miller AEAD200 LegendMiller 375 Xtreme plasmaLincoln WeldPak 100Victor O/A
Reply:An "intermittent weld" avoids the severe warping that an "all-around weld" will create. But, I am guilty of pretzel logic project welds from time to time.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by SquirmyPugPicture a T-joint, the flat bars edge is welded to a face of the tube. (I think that is what he wants to do)  If I were doing this I would lay the flat bar against the side of the tube on both sides and stitch weld the top and bottom leaving the ends alone (the part across the tube).
Reply:Originally Posted by farmersammYou always reinforce the flange, not the web.  The flange does the work.
Reply:Originally Posted by CEPI wish I had a dollar for every beam I've done like this over the years.
GMT+8, 2025-12-26 21:24 , Processed in 0.070510 second(s), 18 queries .
