Cub Lo-Boy 154 snow plow
发表于 2021-8-31 23:28:40 | 显示全部楼层 |阅读模式
this past summer my son purchased $950 of craigslist steel for $75. I think he might be turning into a repurposer like his dad, grandpa and great grandpa.  then this past fall he bought a 154 lo-boy.  it came with a 60" mower.  last week he said, "could we build a snow plow?".  yep, we can do'er. he wanted to build the blade from scratch but i suggested to buy a used blade and we could build from there.  he's has a line on one now.   pictures were hard to find and we settled for some ok pics on a tractor for sale site.  scaled the measurements as best we could to duplicate original.  most of  the parts are made from 3/8" plate, some 1/4" plate and 3/4" round.  bolts are 1/2" grade 5 and jam nuts. more parts need to be made.  still need to purchase a spring for "rocker arm assist". helps to lower plow.  i guess the tractor has no down force when it lowers. this is our progress so for.  thanks for looking, Dave. Attached Images
Reply:more pics. Attached Images
Reply:last one for now.  more to come.Dave. Attached Images
Reply:Lookin forward to some action pictures or video.We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:Hi Dave! I guess you now to watch out for the clutches on these units. Attached ImagesLearning one rod at a time
Reply:most plows don't need any help lowering, their own weight does that.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Originally Posted by Vince_oHi Dave! I guess you now to watch out for the clutches on these units.
Reply:From my friends that own have owned them, they are real pricy to replace, not to mention a real PIA. Some have tole me that the input shaft is NLA, but DONT quote me on this.They are way uder powered for their size there for lots of crasked heads are comen. Ive passed up a few cause the clutches were bad one them.Learning one rod at a time
Reply:a little progress this weekend.  test fitted parts.  needed to make some adjustments for bolt holes.  took some measurements to make thrust bars, plow frame and remainder of lift assembly.pic 1, tractor the plow is being fitted for.pic 2, frame plates and partial view of lift assembly.pic 3, lift at front of tractor.pic 4, 3/4" round welded to 3/8" plate. chamfer the end and welded with 3/32 7014 at 85 amps.pic 5, final pass on one end.  sorry forgot to take pics of prior passes.Dave. Attached Images
GMT+8, 2025-12-26 19:40 , Processed in 0.098849 second(s), 18 queries .
