Aluminum Guard
发表于 2021-8-31 23:28:39 | 显示全部楼层 |阅读模式
Finished this last night. Not much room to work with. I definately have more confidence welding w transformer based machine. I did this with an everlast 250ex inverter. The customer was happy anyway. Attached ImagesHammerFile Big Hammer------------------------------Here, let me Google that for you...
Reply:Is that going to cut the airflow much on the belt?? would some holes help keep it safe and add some more air flowMillermatic DVIMillermatic 251Older buzz box Cheap 120 welder
Reply:Originally Posted by landmanIs that going to cut the airflow much on the belt?? would some holes help keep it safe and add some more air flow
Reply:looks good man. Play with your settings on the machine and that inverter will walk all over the transformers. But i does take some time to get use to the inverter. i run a synchro right now but will be getting a 250ex here shortly, just waiting on a check in the mail..... but other wise looks good.
Reply:If you want it to feel like a transformer machine, set the waveform to "sine wave" instead of square wave and turn the frequency down to 60 and you'll be set up just like the old machines
Reply:Originally Posted by ironmangqIf you want it to feel like a transformer machine, set the waveform to "sine wave" instead of square wave and turn the frequency down to 60 and you'll be set up just like the old machines
Reply:They recommend not using pure tungsten with an inverter. But rather 2%.  Turn the machine to dc + if you wanna ball your tungsten, then set it back to ac.
Reply:Originally Posted by lamenameI didn't see anywhere in the rules where there could be holes. It is a drag sled and goes for a very short distance. Cooling shouldn't be an issue. Found out Im not done though, revision 596 lol. front radius needs to move up about 1/8".
Reply:I'm like you, I like pure in a transformer. You will learn to like the inverter and will also see the need for both. I like Orange Tungsten in my inverter it gives me a good round end like a fresh pure.www.performancealuminumfabrication.com
Reply:Thats a nice guard there!... Enough about that.. whats the specs on the slead!!? LOL! She looks like a goood time!Owner G&S Mobile Welding & Millwright Services, LLCSpencerville, Ohio Adult Ed. Instructor at Apollo Career Center Lima, Ohio
Reply:Originally Posted by HondarussThats a nice guard there!... Enough about that.. whats the specs on the slead!!? LOL! She looks like a goood time!
Reply:You can change the frequency balance to focus the cleaning more. Its hard to explain, and jody doesx a really good job. Watch video 2 of this series. http://m.youtube.com/#/watch?desktop...Efn1twUo&gl=US
Reply:Nice looking work there!Thermal Arc Fabricator 2101970 Lincoln RedfaceMiller 150 STLStill need a Syncrowave and a plasma and a milling machine and a lathe and a bigger shop and a....
Reply:Originally Posted by astaindsoul5446You can change the frequency balance to focus the cleaning more. Its hard to explain, and jody doesx a really good job. Watch video 2 of this series. http://m.youtube.com/#/watch?desktop...Efn1twUo&gl=US
GMT+8, 2025-12-26 21:24 , Processed in 0.099313 second(s), 18 queries .
