TIG Rod Holder
发表于 2021-8-31 23:28:39 | 显示全部楼层 |阅读模式
Well it been a while since I have posted so here was todays project got bored.Need a place to put my ever expanding tig rod collection just  ran out of room. Looked all over this fourm nothing was for me so I winged it.Took out a piece of .056 wall 1" tubing stuck it in my JD2 model 4 bender pulled a 180 degree bend with 3'  legs. made a bracked out of angle used existing holes in the bottom the my Precision tig 225 and another up to for added support. welded in some supports and put some tubing on to at a 80 degree angle and wala tig rod holder.  Not painted yet I will get to that next weekend.Also as way earlier project is my plasma mounted  on top of my tig I made it removable it is welded onto the eye bolt that is in the top of a lincoln precision tig. Attached ImagesDonnelly Small Engine & WeldingFoley AlabamaLincoln 225 TigLinoln 215 migHypertherm Powermax 65Ellis 1600 sawEllis 6000 belt grinderJD2 Model 4 tubing benderAtlas  12"X54" metal latheLots of large hammers
Reply:The only thing that would make this a better set up, is it were Blue instead of Red.....  Just kidding great set up.  Walt
Reply:Nice deal!
Reply:Originally Posted by stuk4x4The only thing that would make this a better set up, is it were Blue instead of Red.....  Just kidding great set up.  Walt
Reply:Lots of Lincoln haters!!!!!  Are you mad cause you could not afford the best so you settled for second best. JUST KIDDING and age old debate that will never be settled. But I do love my RED stuff. The metal brake is a Black Bull Tractor Supply special 36 inch brake up to 16 ga  hard to beat for 3bills.Donnelly Small Engine & WeldingFoley AlabamaLincoln 225 TigLinoln 215 migHypertherm Powermax 65Ellis 1600 sawEllis 6000 belt grinderJD2 Model 4 tubing benderAtlas  12"X54" metal latheLots of large hammers
Reply:Originally Posted by worm122Lots of Lincoln haters!!!!!  Are you mad cause you could not afford the best so you settled for second best. JUST KIDDING and age old debate that will never be settled. But I do love my RED stuff. The metal brake is a Black Bull Tractor Supply special 36 inch brake up to 16 ga  hard to beat for 3bills.
GMT+8, 2025-12-26 19:40 , Processed in 0.083820 second(s), 18 queries .
