fusing 18gauge (TIG)
发表于 2021-8-31 23:28:36 | 显示全部楼层 |阅读模式
this new company i started at today welds hydrogen fuel cells, or at least will be in a week or so. today we practiced all day welding 16gauge coupons. somtimes using filler.  we practiced for a test we will be taking later this week fusing 18 gauge(i know dumb). fusing is easy enough, but they are asking for a perfect burn through on the root. heavy aluminum backing to reduce the sugaring to 0. it takes a lot of heat to burn all the way through the 16gauge and the perfect amount to keep the bead flat instead of concave. also help from god to keep the sugaring to nill. any helpfull hints? 3g downhill test w/ 18gauge stainless.
Reply:Not quite sure what your asking?   Is  there a gas back?  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
GMT+8, 2025-12-26 21:24 , Processed in 0.070093 second(s), 18 queries .
