grounds
发表于 2021-8-31 23:28:34 | 显示全部楼层 |阅读模式
would  it be a bad idea to use a small chuck of copper bussbar to 4 awg welding cable to not have to pull out two or three different ground cable i would be using the plasma and a mig welder on this ground system. idk if i need to worry about the control boards in the mig?2-Lincoln idealarc 250/250, lincoln 225 ac/dc welder, lincweld ac 180c, hobart handler 210, hobart stickmate lx 235/160, Hypertherm Powermax30local 26 I.B.E.W Electrician
Reply:Originally Posted by fhsfiremanco1would  it be a bad idea to use a small chuck of copper bussbar to 4 awg welding cable to not have to pull out two or three different ground cable i would be using the plasma and a mig welder on this ground system. idk if i need to worry about the control boards in the mig?
GMT+8, 2025-12-26 19:40 , Processed in 0.092404 second(s), 18 queries .
