Ultra Flex
发表于 2021-8-31 23:28:30 | 显示全部楼层 |阅读模式
Anyone know a place that will sell Ultra Flex welding lead by the foot?    My new stinger V just showed up and i cant see putting the crap welding lead the LWS's around here have on it and i dont really want to buy a 250' spool.     just 25'Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Try Ebay, I believe i saw it there before. I prefer Ultra flex also.American by birth Southern by the Grace of God
Reply:https://weldingsupply.com/cgi-bin/ei...:OR:304-1270UFIt's a bit cheaper if you buy 50 ft."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by Oldendumhttps://weldingsupply.com/cgi-bin/ei...:OR:304-1270UFIt's a bit cheaper if you buy 50 ft.
Reply:thanks gents picked up 50ft of 1/0Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by Stick-manYep, this is where I bought mine.
Reply:That is a "Stinger V".http://www.stingerv.com/index.php"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by Dualiethanks gents picked up 50ft of 1/0
Reply:I don't always stick weld but when i do i burn a lot of rod and big diameter...    I haven't put a rod in it yet.   I have a couple hundred feet of 3/16 9018 to run in the next couple of weeks.     Prob going to run around 275 amps at at least 80% duty+Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Be careful running those big lo-hy rods with your whip ive ran some before and my stinger got so hot i couldnt hold it anymore. What machine your running it on?~1987 Lincoln Sa-200~~1978 Miller Big 40~ (restored) ~and everything inbetween~
Reply:Havent quite decided yet,  most likely one of the XMT350's .    If all else fails i will just toss the stinger into a bucket of water every couple of rods.      I also picked up another job that i might stick out.     48 welds 9' long i might burn in with some 1/4" 7024.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by DualieI also picked up another job that i might stick out.     48 welds 9' long i might burn in with some 1/4" 7024.
Reply:Check WeldingSupplies closeouts.  Sometimes they have odd lengths available at a pretty decent price (well, if you can handle the shipping).  In my case, my work clamp is on a blue cable - wanted black, but blue was available and on sale.  Also I got 22ft, not 25.  I know.. one day I'm going to be a ft and a half short .Con Fuse!Miller Dynasty 350Millermatic 350P-Spoolmatic 30AMiller Multimatic 200Hypertherm PowerMax 1000G3Miller Maxstar 200DX
Reply:i have had to throw 50' wraps of lead in a line to make it that last 2.5' before.   its the luck of the draw as far as that goesVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-26 19:40 , Processed in 0.069436 second(s), 18 queries .
