I've finally built a proper welding table.
发表于 2021-8-31 23:28:29 | 显示全部楼层 |阅读模式
My projects have gradually been getting bigger and bigger and after building some 18ft sections of railing with a 5ft table I realized that enough is enough. It's 4x8 built mostly out of 2.5x.120 with some 2x14ga.  Iit will have a 4" overhang all the way around, and it recessed the shelves a little so my legs can fit when I'm using it. Tomorrow I'm heading down to get the 3/8" top. I'm also gonna put some heavy MDF in as shelves. I had to show the diagonals. I had never built something so square in my life. I built it on its side and when I finally got it to the floor, it really was a moment of truth when it sat perfectly.  I guess the key is a) perfect cuts, b) lots of clamps, c)take your time and check everything twice, and if it's not right, fix it right there, not later. A little bit of rustoleum and tada! Attached ImagesLast edited by zora; 09-27-2010 at 12:02 AM.Reason: grammarars sine scientia nihil est
Reply:more pics Attached Imagesars sine scientia nihil est
Reply:Im readin about a 32nd out of square lol    Looks very good!!! Nice JobYa gotta spend money to make money!
Reply:Nice looking table.I don't know if you planned it this way but you've got 4 built-in tool mount receivers - 6 if you count the bottom - and pointing in the right direction.Be careful handling that 3/8" plate top.  Mighty heavy.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Wow! Very nice. Wish I had the room to build one that large.
Reply:Originally Posted by duaneb55I don't know if you planned it this way but you've got 4 built-in tool mount receivers - 6 if you count the bottom - and pointing in the right direction.Be careful handling that 3/8" plate top.  Mighty heavy.
Reply:damn that's heavy.  Anyways Just thought I would show a finished pic. Attached Imagesars sine scientia nihil est
Reply:Looks good. I like the rigging on the plate, good idea.
Reply:Very nice. Just remember, space creates clutter. If that was mine, it would 80% filled, and I would be working on the ground!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:What??? you have room to work on the ground??? I'm jealous lolNever argue with an idiot. They drag you down to their level, then beat you with years of experience.
Reply:I wish I had the hindsight to load your plate out the back of the ute the way you did.Stupid me just loaded a 5' x 3' 1/2" plate into my trailer and once home slid it out the back on the floor and made the table upside down on the plate. I then had to turn the table over. I had no cranes or winches, and had to move the heavy sucker on her feet without killing myself in the process. It took a lot of effort and hurt my back !! Never again......
Reply:Thats a table right there!! that thing would hold a house up, nice build!!
Reply:Nice build !!!! you used pipes it rolled right on your table.
Reply:Nice table, I wish I had a table that big!
Reply:Nice table, and I like how simple it is. as Duane Mentioned you've got 8 useable receiver points and 4 more down low. You mentioned vice and grinder for use in them. Aslo you can have bending dies, sheet metal shears, Ring roller, You could even go so far as a sheet metal break (using both sides).Are you going to do anything to allow for clamping in the center of the table or are you just going to weld on some dogs when needed?There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:great looking bench - with a driveway like that, it would bake a big sound if it got away from you!Thermal Arc Fabricator 2101970 Lincoln RedfaceMiller 150 STLStill need a Syncrowave and a plasma and a milling machine and a lathe and a bigger shop and a....
Reply:I like your table alot. I could really use one just like it. Would you mind if I borrowed your design?
Reply:Awesome job!
GMT+8, 2025-12-26 19:39 , Processed in 0.111475 second(s), 18 queries .
