Replacement Decals?
发表于 2021-8-31 23:28:23 | 显示全部楼层 |阅读模式
So here's the story, i picked up a Hobart Performer 16 Which runs excellent but the Sheet metal leaves little to be desired which i knew i was going to have to redo when i bought it. The metal work and paint i can take care of but what I'm trying to figure out is how i go about Replacing the Decals on it. The hobart ones on the side are easy enough but the Main Control panel layout sticker is what i'm having trouble with, I figure there isn't a chance in hell of finding a new Decal so i was thinking i could get one made up at a local sign shop problem is that most of the bottom half of the decal is faded/worn right off so i what need is a Picture of the front panel i could take so they know what to put and where.I looked online for a picture but all the ones i could find had the decals faded or missing all together.Also its the older model with the Big turn dial/handle and fine control. P.S - Had no idea where to put this, A restoration forum would be cool!Miller Dialarc HF-P w/ Water CoolerMiller Regency 200 w/ Miller Spool gunHypertherm Powermax 65
Reply:Reid,I think the engine is called a Onan Performer 16.The welder could be an Hobart 8500 or Hobart Champion 16 etc...Try posting some pictures.Good Luck, someone will help out
Reply:Originally Posted by JJWReid,I think the engine is called a Onan Performer 16.The welder could be an Hobart 8500 or Hobart Champion 16 etc...Try posting some pictures.Good Luck, someone will help out
Reply:Haven't taken any pictures since i picked it up be here's on from the ad Miller Dialarc HF-P w/ Water CoolerMiller Regency 200 w/ Miller Spool gunHypertherm Powermax 65
Reply:http://www.hobartwelders.com/service/owners-manuals/Go hereSelect modelEnter serial numberThe manual usually has a pic of the front labeled what everything does Attached ImagesLast edited by AMC724; 09-22-2013 at 06:45 PM.
Reply:Originally Posted by AMC724http://www.hobartwelders.com/service/owners-manuals/Go hereSelect modelEnter serial numberThe manual usually has a pic of the front labeled what everything does
Reply:The best one I could fineFound here:http://www.purplewave.com/cgi-bin/mn...21025/U9582/11
Reply:Originally Posted by AMC724The best one I could fineFound here:http://www.purplewave.com/cgi-bin/mn...21025/U9582/11
GMT+8, 2025-12-26 19:39 , Processed in 0.133878 second(s), 18 queries .
