30A spool gun storage.....?
发表于 2021-8-31 23:28:21 | 显示全部楼层 |阅读模式
What do you guys do to stow your spool guns when running a dual gun setup? I have a MM252 with a 30A spool gun and the MIG gun, I'm sure there is a better way to store the 30A on the machine than just coiled up on top. Any of you guys have a slick hanger idea?Miller Dynasty 200DXMiller 252 Miller 250xMiller Syncrowave 250Miller AEAD200 LegendMiller 375 Xtreme plasmaLincoln WeldPak 100Victor O/A
Reply:empty dewalt tool cases work nice for storage of other toolsMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Originally Posted by WookieWeldingempty dewalt tool cases work nice for storage of other tools
Reply:This is the one that comes with the low bottle rack as an accessory for the MM252.  It will hold your cables and there are two receptacles for both the mig gun and the spool gun.  There are two pipes at the top that act as holsters.http://store.millerwelds.com/commerc...?ProdID=300337Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:doesn't the 252 have a hanger on the side like the 251?My name's not Jim....
Reply:I like that idea Doug, I hadn't seen that option yet. I was planning on making a dual tank setup anyway, I guess I'll copy their design and build a "tree" of sorts. Thanks!Boost, there is no side hanger on the 252. The front grab handles are well designed to hang the MIG gun, but no provision for the spool gun. 7A749, I'm constantly switching between aluminum and steel so I leave mine attached. The 30' of cord is more of a nuisance to store than the gun itself.Miller Dynasty 200DXMiller 252 Miller 250xMiller Syncrowave 250Miller AEAD200 LegendMiller 375 Xtreme plasmaLincoln WeldPak 100Victor O/A
Reply:This is what I did for my MM200 for storage of its SM-1 and other assorted accessories, supplies and tools.  Spool gun and its cables store on top shelf.http://weldingweb.com/vbb/showthread.php...ves&highlight=MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:At work I have one of those dual cylinder rack/"trees" on my mm252. It's nice.No the 252 does not have the fold out holder like the 251 has.My 30a at home stays rolled up in a 20" ridgid canvas bag
Reply:Good looking rack Duane, I like the 'ol MM200!7A749, great idea for the TIG pedal, is it depressed to fit in there? I may steal that idea for my Syncrowave 250...I've been thinking about making some sort of hanger that would fit over the tank valve (below the valve obviously) and let me hang cables off the tank. Any reason this idea wouldn't/shouldn't work?Miller Dynasty 200DXMiller 252 Miller 250xMiller Syncrowave 250Miller AEAD200 LegendMiller 375 Xtreme plasmaLincoln WeldPak 100Victor O/A
Reply:I just took some flat bar and made a J that had a wing on the top to reach to the screws on the center of the machine. That was. For the spool gun. Then for the mig gun, I made an extended front handle and just coil it loosely on that.
GMT+8, 2025-12-26 21:28 , Processed in 0.133654 second(s), 18 queries .
