Quickie Log Burner
发表于 2021-8-31 23:28:20 | 显示全部楼层 |阅读模式
Just knocked this up yesterday from an old gas bottle,Done in a hurry but still looks and performs OK.Plasma cut door and flame shapes,Did not bother with any air vents or grate ,as it is intended for wood only.Cut down a T hinge,Drilled it 12mm and plug welded to look like rivets.Hand formed short tube and welded it to the top so the flue is detachable.Don't take any notice of the smoke in the first picture,it's just the high temp paint solvent burning off,I think the cut-outs in the door are quite nice when the flames are dancing about. Attached ImagesLincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:Interesting look. I know a couple of people who might like that idea for a fire pit for their patio..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:That really looks good. Would make a good burner for a deck, patio as DSW stated or possibly a small building. I have a full appreciation of heating in England, lived there 10 years. How did you neutralize the gas fumes prior to cutting/welding????GeezerPower Mig 255C185 TIGBlue 175 MIGRanger 8 Kohler 20HP1974 5K Lincoln/Wisconsin Powered (Cherry)Victor/Harris O/AK 487 Spool Gun
Reply:Now we know what to do with the old 20 pounders!Thanks for posting!
Reply:I might be tempted to tack on some expanded metal on the back of the door to intercept the sparks.Otherwise, an interesting idea.Cutting into a propane tank would make me a bit nervous even if it had been open for some time. What technique did you use for the initial cut?
Reply:I have cut into quite a few gas bottles, My procedure is to remove the valve and fill with water and then leave for a couple of hours, Then leave upside down to drain,Finally just before cutting I purge with 100psi compressed air for a couple of minutes.Never ever had even the slightest hint there was any remaining gas fumes,To be even more safe you could always leave the air purge line blowing while you make the initial cut.I have built more complicated burners before with air regulators,sealed doors and ash pans etc, but this one is purely for outdoor use and only took a couple of hours to make.The three feet are cut from the raised collar that protects normally protects the valve.Last edited by gordon stephenson; 11-12-2011 at 09:04 AM.Reason: additional infoLincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:Great recycle job on an old tank and I really like the door. I'm sure someone is saying " Now where did I put that old tank?".
Reply:Pretty slick. I like it. Not a lot of tanks left around here with that much of a base ring on them tho. A guy would have to spend a little more time to fab up something else up."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Originally Posted by gordon stephensonI have cut into quite a few gas bottles, My procedure is to remove the valve and fill with water and then leave for a couple of hours, Then leave upside down to drain,Finally just before cutting I purge with 100psi compressed air for a couple of minutes.Never ever had even the slightest hint there was any remaining gas fumes,To be even more safe you could always leave the air purge line blowing while you make the initial cut.I have built more complicated burners before with air regulators,sealed doors and ash pans etc, but this one is purely for outdoor use and only took a couple of hours to make.The three feet are cut from the raised collar that protects normally protects the valve.
Reply:going to start one using a large size bottle, that stan around 4ft tall, maybe incorporate a small oven with a door.Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:Nice job.http://www.facebook.com/profile.php?id=100000825140116 Lincoln Weldanpower Model # AC-225/DC-210/6 portable,LN-25 suitcase feeder,Harbor Freight 80 AMP Inverter DC Tig
GMT+8, 2025-12-26 21:29 , Processed in 0.068723 second(s), 18 queries .
