115/220v stick welders
发表于 2021-8-31 23:28:17 | 显示全部楼层 |阅读模式
hey now.i was welding today and thinking that sooner or later im gonna want a welder that has input for both 220v and 110/115. not necessarily right now. but i can see myself doing that. especially when the time comes for me to upgrade my generator. my question to you guys is even on 110/115v, does the miller maxstar 150 or lincoln invertec155 perform better than what i currently own, a thermal arc 95s?reason being thermal arc released a couple of machines since i got the 95s, the 161s, 161stl and now the 201 and i was curious as to how they compared to the miller 150 and lincoln 155the grand ol' opry aint so grand anymoremiller maxstar 150sworking on an oxy/acet set up
Reply:A stick welder that draws 40 Amps on 208/220 volts will require 80 Amps on 110/115 volts.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:The 150 amp inverters will definitely run better, but fi you don't have a dedicated 20 amp breaker, you will only be able to weld at about 60 amps for any length of time.
Reply:The input data in the manual on the TA is a bit sketchy. Looks like the Maxstar 150 on 115v power has an edge on the TA95s, if nothing else because it will draw fewer amps to run the same  output from what I can tell. If you want a machine with max power on 115v you need to go up to the Maxstar 200 however. It will do 125 amps on 115v 50% duty cycle, but you will need 34 amps to do so. ( about what it looks like the TA needs to put out  90 amps if I'm reading it right) Thats almost 25% more amps than the 150 is listed at in the manual..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWThe input data in the manual on the TA is a bit sketchy. Looks like the Maxstar 150 on 115v power has an edge on the TA95s, if nothing else because it will draw fewer amps to run the same  output from what I can tell. If you want a machine with max power on 115v you need to go up to the Maxstar 200 however. It will do 125 amps on 115v 50% duty cycle, but you will need 34 amps to do so. ( about what it looks like the TA needs to put out  90 amps if I'm reading it right) Thats almost 25% more amps than the 150 is listed at in the manual.
Reply:Originally Posted by outlawskinnydwhat about the 161s from ta and the lincoln 155?
Reply:Originally Posted by DSWYou do realise all I do is go to the web site, look up the manual and READ it to find the specs on the machines don't you?.
Reply:Why not do it all in one?   get a Lincoln Ranger 8 or 225 or similar used, or new if you have the $$   then you get all the welding current you need,  CV support for wire feed attachment and an 8K+ watt generator all in one nice package.   Just fixed up a Ranger 8 myself.  works great...Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Try to fit that Ranger on the front passenger seat of a Ford Focus, my Maxstar fits just fine.
Reply:Originally Posted by DSW Huh? Small inverters draw very little power compared to a transformer machine. To run a standard Tombstone you need 50 amps at 230v, or about a 12 Kw gen set. The Lincoln 155 needs about 6 kw. That would give you FULL output on 220v power also not 110v. Or you just get a small gereator welder like a Weldanpower, Bluestar etc and skip the inverter.You do realise all I do is go to the web site, look up the manual and READ it to find the specs on the machines don't you?.
Reply:Originally Posted by soutthpawWhy not do it all in one?   get a Lincoln Ranger 8 or 225 or similar used, or new if you have the $$   then you get all the welding current you need,  CV support for wire feed attachment and an 8K+ watt generator all in one nice package.   Just fixed up a Ranger 8 myself.  works great...
Reply:We are talking about something a bit different. I'm not telling you how thick they weld, I'm telling you what the output is listed as. These sorts of specs are easily repeatable if you have  a load bank and want to test the machine. It's some what like comparing amps on a small mig. You won't get the same performance from a small mig thats rated at 90 amps @ 20% on 115v (MM140) that you will from a machine thats rated at 110amps @ 20% on 115v (Passport Plus). These are hard numbers based on the machine electronics and give some one a base line on performance. Also we are no longer talking about $500 entry level machines, but mid to upper grade professional industrial machines costing $1500 or more.You as the welder should have some idea how many amps you can run say 1/8" 7018 on and what performance you will get on your material. You use that experience combined with the base numbers to decide if that machine will do what you want. You are attempting to push the limits on what a "small" 115v machine will do. Thats a very small niche market. You pay big money for those small gains. The Maxstar 150 has a list base of about $1000, the Maxstar 200 that would give you 25 extra amps on 115v will cost you $2250 list. You'd better really want / need that extra 25 amps if you are going to drop an extra $1250 on it just to run on 115v power. In the mig example above, the MM140 lists at $860, the Passport at almost $2100. Again you are paying big bucks for a small gain in power, but in some cases it's well worth it. Note you can get more power for way less money if you simply go to 220v. You can easily match the performance of the Maxstar 150 or 200 on 115v using a 225AC Lincoln on 220v that you can get used for $50-150 and new for less than $400. You don't want to hear this because it doesn't fit your situation right now. No matter how hard you try you won't match the performance of 220v on 115v if the machines are even close in quality. If you want more performance you have only a few options. One: pay BIG bucks for a very small increase in power as shown above. Two: find some way to get 220v power to a machine at your location. Unplug the range and use a 100' 220v extension cord to get outside. I had to use this option to weld in the drive at one apartment I lived in. The next place I ran the cord out the basement window to the yard and used the dryer outlet. Three: Get yourself a genset welder or dedicated genset and run off that. Fourth: Look into renting "shop" space rather than just a storage area..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:It is hard to say how a Maxstar compares to a TA 95 in arc quality since I only have the Maxstar.  If your happy with how the TA 95 runs then you have a certain expectation of what you want. I have an older Maxstar 140 that runs 3/32" 7018 just fine at the end of a 100' extension cord on 120v and when its on 220v its even better. These last two weeks I have been using my Maxstar and a Miller Big Blue 500 and as far as arc quality you can't tell a difference but the Maxstar (arc) sound wise runs smoother.  I also have a TA 185 on stick mode it is rated 160 amps @ 40% duty cycle and it has no problem running  5/32" 7018 and 3/16" 6010. If I picked from your list I would possibly give the TA 161s a try since it has a few more amps and lift start tig.
GMT+8, 2025-12-26 21:23 , Processed in 0.094285 second(s), 18 queries .
