tig torch to gas drive
发表于 2021-8-31 23:28:15 | 显示全部楼层 |阅读模式
ok so my question is...how do i go about hooking up my tig torch to my gas drive?  what do i need to get just a quick connect and cable?  now im asking this without going to the garage to look at it so i might be able to figure it out myself im just too lazy tonight after a long hot day under the hood.  any help will be greatly appritiated.ryanA GRINDER AND SOME PAINT WILL MAKE A WELDER WHAT HE AINT
Reply:What torch???Vinnie
Reply:http://weldingweb.com/vbb/showthread.php?t=38106 that should get you started_______________________OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
Reply:any torch.  i have a small 95 amp tig that i got pretty cheap but i dont do a lot of tig.  id like to sell it and just run tig off my gas drive which is what i should have done to begin with.A GRINDER AND SOME PAINT WILL MAKE A WELDER WHAT HE AINT
Reply:thanks trouble007A GRINDER AND SOME PAINT WILL MAKE A WELDER WHAT HE AINT
GMT+8, 2025-12-26 19:40 , Processed in 0.071662 second(s), 18 queries .
