NEW Lincoln AC/DC 225/125
发表于 2021-8-31 23:28:13 | 显示全部楼层 |阅读模式
I just purchased my first welding machine a Lincoln AC/DC 225/125. The switches seem to be hard and I have not managed to change them and I did not want to put additional pressure. I guess this is not normal and maybe there is a lock. I read the manual but there is nothing listed in it. Your help is appreciated as I am dying to test it ASAP.
Reply:I bought mine new and the switches were very stiff.  Just don't move under load and you should be fine.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Thanks all for your fast responses. I will give it a try again but it is VERY stiff.
Reply:I dont know much of the new ones, assuming it has the white plastic pointer that you rotate to set the amperage.  If its like my 80s version try pushing in on it before turning.Briggs weldnpower 225/210/cvLn-25 suitcaseMillermatic 130
Reply:Originally Posted by WinmacI dont know much of the new ones, assuming it has the white plastic pointer that you rotate to set the amperage.  If its like my 80s version try pushing in on it before turning.
Reply:Thanks guys. Mission accomplished. It's makes a click noise when changing it from position. I was not aware of that. Will tried later when everybody is at home. Debuting at home for the very first time.Many thanks again. Sunny regards from Aruba.
Reply:Give it, oh ... 25 years or so, it will soften up a tiny bit.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
GMT+8, 2025-12-26 19:41 , Processed in 0.114196 second(s), 18 queries .
