Fix what?
发表于 2021-8-31 23:28:11 | 显示全部楼层 |阅读模式
A guy brought this by the shop today and wanted a goat cage built on it. I had to ask, "On that?" It had to be the very worst case of a trailer I'd ever seen. It was still being used too. It was total junk and I was able to convince him to take it across the scales at the junk yard.It had two different kinds and heights of tires on it, one radial and one grave digger. There was only 4 lug nuts on one wheel and 3 on the other.I counted 9 pieces of metal used to make the axle stronger.The hitch had a long gap along one side where the weld had burned completely through when it was built.I have absolutely no idea what the 4x4 that was duct taped between the axle and the frame was for. It looked important though.Definitely a custom built trailer. Attached Images
Reply:Cut it into dozens of pieces and tell him your saving him a boat load of future headaches and possible lawsuits
Reply:What a piece of...............junk.Is there a good piece of metal or part on the whole thing, looks like something you would carry goats in Egypt with, add a donkey and away you go.
Reply:that there is too funny. Grab the torch buba.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:You are gonna get in trouble with that milk crate in your possession yaknow.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:If the 4x4 is pressure treat I would save it for cribbing, about it, maybe a spare lug nut or 2. That duct taped block probably has something to do with a failed spring. I would run from that one, and the owner , a little questionable that he even thought about adding too and using that."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Yeah, I'd rather have the goats walk where they're going than make them ride on that thing!!
Reply:Is that rope structural?  I'll bet all of the holes make the thing go faster (Speed holes!)If not cut down on the overall weight.
Reply:wow, just wow.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:........posting pics of my BEST work again............6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:I don't see the problem? Is there something wrong with a weld somewhere or something?
Reply:After WWII Guy got welders and started to build trailers out of every scrap they could find. I have seen alot of trailer like this built and repaired with what ever was handy. I would not usit but the fact it is still around garantes that it has held together and been used a lot. I haul scrap Iron and clean up old farm steds I run on to things like this all the time.
Reply:Originally Posted by zapsterYou are gonna get in trouble with that milk crate in your possession yaknow.....zap!
Reply:It looks like the 3 out of 5 lug nuts that are there were put on backwards.
Reply:Originally Posted by backpurgeNo kidding. I had done a welding job in a dairy processing plant .Finished and loaded up hand tools, cords and stuff in a couple of those stupid milk crates. Supervisor blew his lid and told me that's a criminal act to take or  posses  milk crates unlawfully. My smart azz reply.... I 'll spot ya  $2 and I keep them both. He told me they COST the company $13 bucks a piece. Sounds like B.S to me. Come to  think about it, probably part of the reason that nasty white milk costs the consumer so much.Givem back or go to jail man !!!!!
Reply:The 4x4 block was used as a bump stop for when he over loaded the trailer I guarentee that. I have seen acouple of them around here I was called out to a farm one time that had the same set up. He had a piece of 4x4 block lag bolted to it and it was to keep the spring from sagging and letting the tire hit the fuel tank he was hauling. It was in similar condition Except had bailing wire instead of the twine. I looked at the 500 gallon diesel tank and then the trailer and told him I couldnt be a part of that and left. Hahaha some people just don't under stand what they do endangers other people to lol.Vantage 300 kubota ,miller 304 xmt ,lincoln ln 25 pro , ranger 305 G, plenty of other tools of the trade to make the sparks fly.
Reply:The 4x4 block is the overload spring.http://www.facebook.com/profile.php?id=100000825140116 Lincoln Weldanpower Model # AC-225/DC-210/6 portable,LN-25 suitcase feeder,Harbor Freight 80 AMP Inverter DC Tig
Reply:wow....
Reply:I just knew you guys would want to see that. I actually thought about building him a cage that would fit on the trailer and let him attach it. Then I started thinking about whether I would want my wife driving on the same road as this thing was getting towed and started talking to him about the scrap yard. I really aam glad he agreed with me.
Reply:"Yep..When I was drumming in rock bands I had 12 of them for under my drum riser"..now we know where that stack of dimes rythm comes from.miller thunderbolt 250vlincoln square wave tig 175 prolincoln idealarc mig sp250everlast tig 210EXTeverlast power plasma 50chicago electric (hf) 130 tig/90 arcchicago electric 90 amp flux wire3 sets oxy/acet
Reply:Originally Posted by BobI just knew you guys would want to see that. I actually thought about building him a cage that would fit on the trailer and let him attach it. Then I started thinking about whether I would want my wife driving on the same road as this thing was getting towed and started talking to him about the scrap yard. I really aam glad he agreed with me.
GMT+8, 2025-12-26 22:53 , Processed in 0.144623 second(s), 18 queries .
