Octagon fire pit
发表于 2021-8-31 23:28:11 | 显示全部楼层 |阅读模式
Octagon fire pitHere is a fire pit I just built It is 5' across and made mostly from 1/8' stuff. The uprights are round tubing and the horizontal ones are square tubing. I might add some bling from king metals. I cut the panels with a plasma cutter from the school bus garage. All I need is some warmer temps. – tunes and few cold ones!!!! Attached ImagesDave ReberWadsworth Ohio
Reply:Plus I have to paint it. I just looked at the picture the panels have a 1" gap between themselves and the frame.In the picture it gives a different illustion.Dave ReberWadsworth Ohio
Reply:warmer weather????? 5ft across get that baby cooking and you will be plenty warm....invite a few friends and even cook over that...looks nice, but I have a feeling with all the spaces around any little breeze and embers are going flying..mabe in the snow its not a problem , but in the warmer weather..fire hazzard...Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:You might be right about a fire hazzard. I never liked my house that much.Dave ReberWadsworth Ohio
Reply:I like it
GMT+8, 2025-12-26 21:29 , Processed in 0.074166 second(s), 18 queries .
