Hi there I would like to use my Lincoln classic as a power source to run tig. With ac capabity. The Lincoln is cc dc machine. Budget is 4000 and would like to be portable. Thanks for your advice.LeighLincoln Classic 300DLincoln SA 250Red d arc 300 dieselRanger 305Miller 302 Trailblazer12V Extreme SuitcaseMiller 200 DXVictor O/A torches3 dodge dually cummmins
Reply:Being a DC machine, the only way you would be able to run AC TIG is if you had enough aux power to run a plug-in TIG machine. Since you're limited to about 15 amps of 220V aux power, I doubt that it would be feasable.
Reply:Thanks. I will have to run it thru my trailblazer. But my Lincoln is my main machine as I am a pressure welder. Thanks for your time and info.LeighLincoln Classic 300DLincoln SA 250Red d arc 300 dieselRanger 305Miller 302 Trailblazer12V Extreme SuitcaseMiller 200 DXVictor O/A torches3 dodge dually cummmins
Reply:It looks like you should be able to get all the goodies you need to AC TIG with the Trailblazer and stay under budget. You'll need a Hi-freq add-on and various ohter accessories to make it work. You can look up the Trailblazer on Miller's website and it will show you the accessories available/needed, or your LWS should be able to hook you up.
Reply:Thanks.. appreciate that.. just was kind of wishing there was a work around so I could use my lincoln.. no harm no foul I guess for asking.. CheersLeighLincoln Classic 300DLincoln SA 250Red d arc 300 dieselRanger 305Miller 302 Trailblazer12V Extreme SuitcaseMiller 200 DXVictor O/A torches3 dodge dually cummmins
Reply:Your other option would be to run a machine like the Dynasty 200 from the 220v aux power on the TB. There are several guys here who run them off Bobcats. That would give you more options than the HF box and give you a portable tig you could use in the shop/ site and not need to run the genset. The big question would be if you needed more amps than the Dynasty could deliver. I doubt that would be the case, as you need to add a cooler and WC torch if you needed that many amps.Personally I'd opt for the Dynasty over the HF box/tig set up. I just see it as being a more versitile setup overall..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by METALiculousHi there I would like to use my Lincoln classic as a power source to run tig. With ac capabity. The Lincoln is cc dc machine. Budget is 4000 and would like to be portable. Thanks for your advice.
Reply:Good point DSW!. I was only looking at it from the amps standpoint. It's good to get other perspectives!
Reply:Originally Posted by DSWYour other option would be to run a machine like the Dynasty 200 from the 220v aux power on the TB. There are several guys here who run them off Bobcats. That would give you more options than the HF box and give you a portable tig you could use in the shop/ site and not need to run the genset. The big question would be if you needed more amps than the Dynasty could deliver. I doubt that would be the case, as you need to add a cooler and WC torch if you needed that many amps.Personally I'd opt for the Dynasty over the HF box/tig set up. I just see it as being a more versitile setup overall.
Reply:Originally Posted by reverse polarityCheck out this link: http://weldingweb.com/vbb/showthread.php?t=38106
Reply:I agree with the Dynasty option. Just keep in mind its 200 Amps max. I'm not sure if that suitcase can push aluminum wire, but when the aluminum gets thicker, you will want that as an option.Con Fuse!Miller Dynasty 350Millermatic 350P-Spoolmatic 30AMiller Multimatic 200Hypertherm PowerMax 1000G3Miller Maxstar 200DX
Reply:I will be getting spool gun for for the aluminum Applications. But will tig all my pipe. I am broke all the time but hey I am having fun. ThanksLeighLincoln Classic 300DLincoln SA 250Red d arc 300 dieselRanger 305Miller 302 Trailblazer12V Extreme SuitcaseMiller 200 DXVictor O/A torches3 dodge dually cummmins |
