Building a propane birthday candle for 100th birthday
发表于 2021-8-31 23:28:05 | 显示全部楼层 |阅读模式
This is a bit off topic but I'm hoping that someone will be able to help me.My mother is turning 100.  As you can imagine, 100 birthday candles would be hard to light and harder for her to blow out.  I know I can buy one of those wax '100' candles but I wondered if I could do better.My idea is to sweat copper pipe with silver solder into a small octagon that I can suspend over the 9" cake.  I would drill 100 holes in the pipe and run propane at low pressure so she can easily blow out the flames.I deal with the piping issues and drill the holes.  I am naturally concerned about safety.  I would rather not incinerate the birthday girl or blow up the room.Any thoughts?many thanks for the advice.
Reply:Since it is for a woman you better get a candle that says "29"Seriously, I don't think the flames will look like 100 individual Flames in a small diameter of 9"probably look like a stove top burner.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Not a good Idea.  John GaultSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:I agree this does not sound like a good idea.  After the flames are blown out you will have 100 gas jets spewing propane into the room.  If you insist n the gas candles, consider a valve so the birthday girl can turn them out.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:One way to get around the hazard of propane after the flames are blown out is have a long fuel hose with a shutoff mid way ... That way you can shut it down right when she blows them out ... Sure thing she couldn't do it by herself ... Make her think she did them all at once ... But the other bother might be the looks of the thing and the fact that sooo many little flames spread out over a fair area generates a big heat overall ... Just try to put your hand anywhere above 100 lit candles ...I have been there, done that ... I have taken the scars and left the smiles to prove it ...  U.S. Marine extraordinaire ...Wars fought, tigers tamed, revolutions started, bars emptied, alligators castrated ...
Reply:If i understand what your wanting to do correctly. I would suggest shopping online for a 100 candle with one wick...one flame to blow out or find the ones and zeros  which would give you only 3 wicks.
Reply:look around on youtube for people who put a lot of candles on a cake. The flames all come together and you end up with one huge firestorm atop the cake that grandma will not be able to blow out.
GMT+8, 2025-12-26 21:22 , Processed in 0.194985 second(s), 18 queries .
