Anyone do flame cutting fore hire?
发表于 2021-8-31 23:28:04 | 显示全部楼层 |阅读模式
Ive used one of the forums seevice providers in the past.  He hasnt been on the forum since june, or answer emails.Anyone have capabilites of flame, water, whatever cutting of steel and aluminum if given a pdf file, or dimensions of such item?  I have some things i want to make this winter and will need the service.Thanks
Reply:Why don't you get a recommendation from the best ? http://www.ruger.com/casting/
Reply:Any local to you welding shop should be happy to have the work along with your money."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:PM sent.
GMT+8, 2025-12-26 21:31 , Processed in 0.199081 second(s), 18 queries .
